resize combox dropdown
Sep 09, 2012 Sep 09, 2012
hi
how do you resize combox dropdown? i have try from the stage with no luck.  it is inside a movie clip.......
thanks
Josh
ActionScript
2.4K
Community Expert , Sep 10, 2012 Sep 10, 2012
if you want to customize/format the text of the combobox, you can assign one (or more) textformat instances.  for example:
var tfor:TextFormat = new TextFormat();
tfor.size = 8;
//if cb is your combobox instance:
cb.textField.setStyle("textFormat", tfor);
cb.setStyle("disabledTextFormat", tfor);
cb.dropdown.setRendererStyle("textFormat", tfor);
p.s.  please mark helpful/correct responses.
show the code you tried and explain the reference to the movieclip parent and the combobox reference.
code
function addComList ():void {
com_txt.addItem( { label: "com" } );
com_txt.addItem( { label: "net" } );
com_txt.addItem( { label: "org" } );
i using flash form components
the movieclip is called form2
if the code you want to use to control your cb is in the same scope as addComList(), use
com_txt.width, com_txt.height
if the code is in the scope of the parent of form2, use:
form2.com_txt.width, form2.com_txt.height
thanks
i think i  am looking to set the font size.
tfor.size = 8;
would you be so kind to explane how that code does what it does? i am trying to learn and i find the stuff on the web doesnt explane how or why, and i learn easiter knowing why/how.
  the dropdown text is fine but when it is in the upstate the font is too smallscreenshot.gif
change the font size to suit your needs.  i wasn't suggesting that size=8 was what you should use.
to learn more about styling a combobox (or other flash components): http://help.adobe.com/en_US/ActionScript/3.0_UsingComponentsAS3/WS5b3ccc516d4fbf351e63e3d118a9c65b32...
size=8 works great in the dropdowns but when an item is picked it is too small
sorry to be a pest, thanks four your help
then use a different size in the cb's textfield:
tfor.size = 8;
tfor.size=12;
sorry for bothering you.      what am doindg wrong? nothing is changing
import fl.controls.ComboBox;
import flash.text.TextField;
import flash.text.TextFieldType;
// custom function we create to populate the comboBox list
// create a new textformat and set the style of it
com_txt.setStyle("disabledTextFormat", tfor);
com_txt.dropdown.setRendererStyle("textFormat", tfor);
tfor.size=11;
com_txt.textField.setStyle("textFormat", tfor);
com_txt.dropdownWidth = 40;
com_txt.dropdown.rowHeight = 10;
com_txt.addItem( { label: "" } );
looks like you have to use a different textformat instance for each:
var tfor1:TextFormat = new TextFormat();
com_txt.setStyle("disabledTextFormat", tfor1);
com_txt.dropdown.setRendererStyle("textFormat", tfor1);
tfor.size=11;
thanks!
Sep 11, 2012 Sep 11, 2012
you're welcome.
where can i learn as3?
my dropdown is to far down from the rest, why me? the issues started when i made my flash full browser. i relize i had to scale everything dwon in flah so it will look right in the browser, everything scaled down easily accpet the combox
there are a number of ways to learn as3.  some people learn best using a book and some via trial and error.
but i think the most helpful way to learn is to start by learning how to use the adobe help files.  especially, the listing of all classes, properties, methods and events.  learning how to use it (you don't need to learn or memorize it), combined with trial and error (or testing in flash) is what works best for me.
any way to move the dropdown? its too low.
you can use its x and y properties to change where it appears on stage:
com_txt.y -= 200;  // will move it up 200 pixels
