1. Re: Creating a list of missing files in Organizer ?
photodrawken Sep 10, 2012 1:00 PM (in response to MichelBParis)Michel,
That's a very interesting idea. A SQL query would be quite easy to devise. Give me a little time to create some missing files and I'll see what I can do....
Ken
2. Re: Creating a list of missing files in Organizer ?
photodrawken Sep 10, 2012 1:33 PM (in response to MichelBParis)Well, if it can be done, it would be a two-stage process:
- Query the thumbs.5.cache database for the missing files, and save the results.
- Open the catalog.pse10db database and create a SQL query using the results from #1 as parameters.
However, I can't determine how the items in the thumbs.5.cache database are linked to items in the catalog.pse10db database: the thumbs.5.cache.thumbnail_info_table.media_id values don't match anything I'm seeing in the catalog.pse10db.media_table.id values....
Ken
3. Re: Creating a list of missing files in Organizer ?
photodrawken Sep 10, 2012 9:25 PM (in response to MichelBParis)Michel,
OK, I got it working. I didn't see the ID links because I was lazy and only looking at the Top 500 rows of the thumbnail_info_table. When I looked at all the rows, sure enough, there were IDs matching the IDs in the media_table.
I'll post the procedure in a follow-up message, but this is a heads up: you're finally going to have to break down and install Database.Net:
http://fishcodelib.com/Database.htm
The procedure is a 4-step process:
- Connect to the thumb.5.cache database and generate a table creation script for the thumbnail_info_table, saving that script as a SQL text file.
- Still connected to thumb.5.cache database, generate a data insertion script for all the data in the thumbnail_info_table, saving that script as another SQL text file.
- Connect to the catalog.pse10db database and run those two SQL scripts, in order, to create the thumbnail_info_table and populate it with the data.
- Run a SQL query to get a list of the fully-qualified filenames of the missing files.
You were right that the thumbnail_info_table.status value of "2" denotes a missing file. I tested by importing 4 images into PSE, closing PSE and deleting those 4 images. I opened PSE, and used "Reconnect...All Missing Files". When that finished, those 4 images were marked as missing. When I finished step#4, I got precisely those 4 images listed.
Ken
4. Re: Creating a list of missing files in Organizer ?
photodrawken Sep 10, 2012 10:11 PM (in response to photodrawken)Here we go, using Database.Net:
- Connect to thumb.5.cache.
- Right-click on thumbnail_info_table, and select "Script As...Create".
- Use Edit...Save As to save it to any convenient directory as
thumbnail_info_table_create.sql - Righ-click on thumbnail_info_table, and select "Script As...Data (Inserts)...File, saving it to that same convenient directory as
thumbnail_info_table_data.sql
(In the Export Options dialog, simply click "OK".) - Disconnect from thumb.5.cache.
- Close any open queries.
- Connect to catalog.pse10db.
- Use Edit...Open and open that
file. - That query will open as a new query window -- click on the "Execute" button.
- Repeat steps 8 and 9 for the
file. - Click on the "New Query" button, and paste this query into the editing window:
SELECT full_filepath
FROM media_table
WHERE id IN (
SELECT media_id
FROM thumbnail_info_table
WHERE STATUS = "2"
ORDER BY full_filepath
12. Click on the "Execute" button.
You can click the "Export" button to save the results to a file in the format of your choice. Here, I've used the "HTML" option:
full_filepath /Pics/nnpcs/000700AB.jpg /Test/000700A2.jpg /Test/000700A5.jpg /Test/000700A8.jpg Ken
5. Re: Creating a list of missing files in Organizer ?
photodrawken Sep 11, 2012 12:43 AM (in response to MichelBParis)I've done some refinements -- the data extraction and insertion take a long time to run and include beaucoup data that we don't need. Using a small subset of the data speeds things up noticeably.
Copy this SQL query into a text editor:
CREATE TABLE [temp_thumbnail_info] (
[media_id] integer NOT NULL
GO
and save the file as
temp_thumbnail_info_create.sql
INSERT INTO [temp_thumbnail_info] ([media_id])
SELECT media_id
where status = "2"
GO
temp_thumbnail_info_t5c_insert.sql
FROM media_table
WHERE id IN (
SELECT media_id
FROM temp_thumbnail_info
missing_files.sql
Then, the optimized procedure goes like this:
- Run the "temp_thumbnail_info_create.sql" script.
- Run the "temp_thumbnail_info_t5c_insert.sql" script.
- Right-click on temp_thumbnail_info, and select "Script As...Data (Inserts)...File, saving it to that same convenient directory as
temp_thumbnail_info_data.sql
- Close any open SQL queries.
- Run the "temp_thumbnail_info_data.sql" script.
- Run the "missing_files.sql" script.
Save the result set as before in a format of your choosing.
Ken
Message was edited by: photodrawken to correct table name.
6. Re: Creating a list of missing files in Organizer ?
MichelBParis Sep 11, 2012 1:08 AM (in response to photodrawken)Ken,
Many thanks and congrats for the excellent job!
It is obvious that few users will use those queries but we have learnt many things from that exercice.
- It would be so easy for Adobe to provide a way to export the list shown in the reconnect dialog as a text file
- We know where the info is stored (thumbs.5.cache) which is a sqlite database
- We already knew that that cache file could be optimized in the 'optimize' process and re-created automatically if deleted.
- If we compare an optimized version of a catalog with missing files and the re-created catalog, of course the size and date created of the original files are lost. The status "2" for missing files has been confirmed. "0" is for normal files, "1" is not known.
We'll see if there is some change in the next PSE version.
Now, before deleting the cache, I'll make a copy not to lose the original data of the missing files...
