1. Re: Adobe Flash Player 11.4 installation via SCCM(Batch File)
GuillyAU Sep 24, 2012 11:56 PM (in response to harsh5094)OK , I just deployed flash player here and it ran like a charmy .
1 - Download the last version of flash ( msi )
- Go to this URL and Download the msi file : http://www.adobe.com/au/products/flashplayer/distribution3.html
2 - Create a "install.cmd" file .
- Create a folder , place the flash player msi file there ( install_flash_player_11_plugin.msi) . Inside this folder , create a file with the name "install.cmd" . Open this file and add the follow lines :
msiexec /qn /norestart /i "%~dp0install_flash_player_11_plugin.msi"
exit /B %EXIT_CODE%
Salve and close the file .
I assume that you know how to create a package / program .
3 - Create a new package
- After create the packge , create a new program for the package . In command line field , click in browse , make sure that you list "all files (*.*)" and click at install.cmd . Select the msi file (install_flash_player_11_plugin.msi) on "Windows Installer" option . also , make sure that "Run with administrative rights" is selected on "Environment" .
Thats should be enough , let me know how it go .
Cheers ,
2. Re: Adobe Flash Player 11.4 installation via SCCM(Batch File)
greenant_qap Mar 7, 2013 5:10 PM (in response to harsh5094)Hi harsh5094,
Did you ever get this working. I am looking for the same thing.
GuillyAU gives me some ideas, but still does not do exactly what you asked.
I would like a single command or batch file that will install both the Active X and Plugin versions of Flash Player (exe or msi - whichever works best), and also copy the mms.cfg file to the destination PCs (If not already there).
I was also going to copy the mms.cfg file to both 32-bit and 64-bit directories, instead of just the 32-bit one you mentioned in the OP.
Currently I have a separate Package for the Plugin and Active X installers, and deploy the mms.cfg file through GPO.
It would be good to have it all install in the single package.
I could possible even include AIR and Shockwave in the same script.
