6 Replies Latest reply on Sep 12, 2012 8:34 AM by sanchousf
      • 1. Re: How get the mesh vertices of the effects "Puppet"?
        Rick Gerard Mythic
        I'm not sure what data you want to extract. Puppet pin keyframe data looks like this:
        Adobe After Effects 8.0 Keyframe Data
                  Units Per Second          29.97
                  Source Width          318
                  Source Height          52
                  Source Pixel Aspect Ratio          1
                  Comp Pixel Aspect Ratio          1
        Effects          Puppet #7          arap #3          Mesh          Mesh #1          Deform          Pin #2          Position
                  Frame          X pixels          Y pixels
                  51          289.175          21
                  59          289.063          17
                  64          287.032          1
                  66          287.023          -3
                  70          287.018          -7
                  74          287.009          45
                  82          287.001          59
                  83          287.001          57
                  84          283.002          49
                  88          283.001          17
                  90          277.001          -1
                  96          277          -5
                  101          279          25
                  103          279          39
                  110          279          43
                  118          269          -86.6667
                  121          269          -266
                  122          271          -256
                  129          273          -236
        End of Keyframe Data
        This is all yoy get when you copy the keyframes. Since this is a scripting question, I'd move the post to the that forum. You'll find it on the AE Forum home page in the right column.
        What are you trying to do with the data?
        • 2. Re: How get the mesh vertices of the effects "Puppet"?
          Mylenium Legend
          The mesh is internal. There is no data that you can simply snatch in a script or expressions. As Rick illustrated already, all you ever get are the pin coordinates relative to the layer.
          Mylenium
          • 3. Re: How get the mesh vertices of the effects "Puppet"?
            sanchousf Newcomer
            I want to implement the export of the effects in the game engine. To do this, I need to know how the entire mesh. If I only use the "Puppet Pin" then I need to write the algorithm distortion. It is quite difficult, and the result of his work will be different from what is achieved would animator.
            P.S. I think you're right about moving the post.
            • 4. Re: How get the mesh vertices of the effects "Puppet"?
              Rick Gerard Mythic
              I don't think that's going to work.
              • 5. Re: How get the mesh vertices of the effects "Puppet"?
                Mylenium Legend
                I agree with Rick. You're betting on the wrong horse if you hope to export this kind of stuff from AE. If you need UV texturing on a mesh, then use a mesh in a 3D program and export it. Due to how the Puppet Mesh is generated, the distorsioss will be quite uneven, anyway and only get worse at lower (texture) resolutions, nothing what I would like to see in a game....
                Mylenium
                • 6. Re: How get the mesh vertices of the effects "Puppet"?
                  sanchousf Newcomer
                  The fact that all the 2D animation done in After Effects and export to the game on "Transform". I would like to implement export "Effects".
