33 Replies Latest reply on Sep 23, 2012 9:59 AM by Andrei1-bKoviI
    Newbie: Comparing Arrays
    donalall Level 2
      I want to create a screen (using just AS3 code) with a number of user input questions on it.
      e.g. Question stem: What is the capital of France?   Answer: Paris.
      I have the code for displaying the "question stem" and the "text entry box".
      But I do not know what code to use to compare the two arrays:
      Array 1: correct answer, Array 2: user input answer.
      User will click a Submit button once they have answered all the questions. i.e. One Submit button.
      I would also like the text "Correct" or "Incorrect" to appear to the right of the text entry box.
      I'm new to AS3 so any changes to the code i've provided would be welcome.
      Below is the code for 3 questions. (without the Submit button code)
      package
      import flash.display.Sprite;
      import flash.text.TextField;
      import flash.text.TextFormat;
      public class Main_questions extends Sprite
      // DEFAULT TEXT FORMAT
      var textFormat:TextFormat = new TextFormat("verdana", 9)
      public function Main_questions():void
      // QUESTIONS IN A LOOP
      var Q_stem_array:Array = new Array();
      for(var i:int = 0; i < 3; i++)
      var Question:TextField = new TextField();
      Question.defaultTextFormat = textFormat;
      Question.border = false;
      Question.width = 300;
      Question.height = 20;
      Question.x = 30;
      Question.y = i * 35 + 70;
      Q_stem_array.push(Question);
      addChild(Question);
      Q_stem_array[0].text = "1. What is the Capital of Ireland?";
      Q_stem_array[1].text = "2. What is the Capital of France?";
      Q_stem_array[2].text = "3. What is the Capital of Spain?";
      // TEXT ENTRY BOXES (TEBs) IN A LOOP
      var TEBfield:TextField = new TextField();
      TEBfield.defaultTextFormat = textFormat;
      TEBfield.border = true;
      TEBfield.width = 200;
      TEBfield.height = 20;
      TEBfield.x = 200;
      TEBfield.y = i * 35 + 70;
      TEBfield.type = "input";
      textArray.push(TEBfield);
      addChild(TEBfield);
        • 1. Re: Newbie: Comparing Arrays
          kglad Adobe Community Professional & MVP
          do you know how to create and populate the two (correct answers and user input) arrays?
          if yes, loop through one of them and compare their elements:
          function scoreF():int{
          var score:int = 0;
          for(var i:int=0;i<correctAnswerA.length;i++){
          if(correctAnswerA[i].toLowerCase()==userInputA[i].toLowerCase()){
          score++;
          return score;
          1 person found this helpful
          • 2. Re: Newbie: Comparing Arrays
            donalall Level 2
            I know how to create and populate the "Correct Answers". i.e.
                var Answers:Array = new Array("Dublin", "Paris", "Madrid");
            But don't know how to create and populate the "User input answers" array.
            Also where would i put the function "scoreF" you provided?
            Would it be in the "buttonClick Handler".
            i.e.   private function buttonClickHandler(event:MouseEvent):void
            • 3. Re: Newbie: Comparing Arrays
              whereever you detect that the user has completed their answer to the current question, use:
              userInputA.push(yourinputtextfield.text);
              and you call scoreF() when the quiz is completed and you want to display the user's score.
              • 4. Re: Newbie: Comparing Arrays
                donalall Level 2
                I want the user to answer all questions on the screen. Then click the Submit button to be assessed on whether they got each question correct or incorrect.
                So not sure if your "push" code handles this or assesses just one question at a time?
                Also how is the "user input array" created? Do i have to have a "var ...:Array = new Array.." somewhere?
                • 5. Re: Newbie: Comparing Arrays
                  yes, you need:
                  var userInputA:Array=[];
                  to declare and define an array.
                  when the submit button is clicked (eg, in your click listener), you can use:
                  for(var i:int=1;i<=n;i++){
                  userInputA.push(this["tf_"+i].text);  // where your input textfield for question 1 is tf_1, for question 2 is tf_2 etc
                  • 6. Re: Newbie: Comparing Arrays
                    donalall Level 2
                    Your "for" statement within "Click listener" displayed an output error message.
                    ReferenceError: Error #1069: Property TEBfield1 not found on Main_Sept13 and there is no default value.     at Main_Sept13/buttonClickHandler() )
                    I'm assuming i have to assign a number (e.g. tf_1, tf_2 etc) to a "input textfield" when i create it
                    Below is the looped "input textfield" code i have. Also should the "var tf_..." line be placed here?
                    for(var i:int = 0; i < 3; i++)          // Text Field Boxes (tf_) in a Loop
                    var tf_:TextField = new TextField();
                    tf_.defaultTextFormat = textFormat;
                    tf_.border = true;
                    tf_.width = 200;
                    tf_.height = 20;
                    tf_.x = 200;
                    tf_.y = i * 35 + 70;
                    tf_.type = "input";
                    addChild(tf_);
                    • 7. Re: Newbie: Comparing Arrays
                      you need to create those textfields.  if you're using code to create them, use:
                      this["tf_"+i]= new TextField();
                      this["tf_"+i].defaultTextFormat = textFormat;
                      this["tf_"+i].border = true;
                      this["tf_"+i].width = 200;
                      this["tf_"+i].height = 20;
                      this["tf_"+i].x = 200;
                      this["tf_"+i].y = i * 35 + 70;
                      this["tf_"+i].type = "input";
                      addChild(this["tf_"+i]);
                      or save yourself some typing and use:
                      with(this["tf_"+i]){
                      border = true;
                      width = 200;
                      height = 20;
                      x = 200;
                      y = i * 35 + 70;
                      type = "input";
                      • 8. Re: Newbie: Comparing Arrays
                        donalall Level 2
                        I copied and pasted your code above for creating the textfields and it gave me this error.
                        Error #1056: Cannot create property tf_0.
                        • 9. Re: Newbie: Comparing Arrays
                          copy and paste the code you used.
                          • 10. Re: Newbie: Comparing Arrays
                            donalall Level 2
                            I tried both bits of code you provided.
                            For example - here is the code i used - your second example.
                            border = true;
                            width = 200;
                            height = 20;
                            x = 200;
                            y = i * 35 + 70;
                            type = "input";
                            • 11. Re: Newbie: Comparing Arrays
                              make your sprite sublclass dynamic or extend the movieclip class.
                              p.s. please mark helpful/correct responses.
                              • 12. Re: Newbie: Comparing Arrays
                                donalall Level 2
                                When you say "extend the movieclip class" do you mean:
                                public class Main_Sept13 extends MovieClip
                                (Wasn't sure how to make the Sprite subclass dynamic so I changed the Sprites to MovieClips)
                                It still brings up the same error.
                                • 13. Re: Newbie: Comparing Arrays
                                  you'll have to make that dynamic, too:
                                  public dynamic class Main_Sept13 extends MovieClip
                                  or, if you want to use sprite:
                                  public class Main_Sept13 extends Sprite
                                  • 14. Re: Newbie: Comparing Arrays
                                    donalall Level 2
                                    Thanks - Dynamic Movieclip worked.
                                    But when i click the Submit button after the input fields are filled in i get this error.
                                    Error #1010: A term is undefined and has no properties.
                                        at MethodInfo-2()
                                    Here is the "Click Handler" code:
                                    // Click Submit Button
                                    for(var i:int=0;i<=3;i++){
                                    UserInput.push(this["tf_"+i].text);
                                    UserInput defined at the top after the class =  var UserInput:Array = [];
                                    "tf_" defined in the For loop for the Textinput fields - code you provided above.
                                    (i'm assuming the problem relates to "tf_"?)
                                    Once i get this working i'll also need to add the Score function you provided previously.
                                    • 15. Re: Newbie: Comparing Arrays
                                      if you only created 3 textfields you shouldn't be checking 4.  use:
                                      for(var i:int=0;i<3;i++){
                                      p.s.  you should start marking the helpful/correct responses so others can quickly find them.
                                      • 16. Re: Newbie: Comparing Arrays
                                        donalall Level 2
                                        Still the same error with the Push code.
                                        TypeError: Error #1010: A term is undefined and has no properties.
                                            at MethodInfo-1()
                                        p.s. I have now marked the helpful responses.
                                        • 17. Re: Newbie: Comparing Arrays
                                          is that code in your Main_questions class?  is UserInput defined AND initialized.  if yes, yes and yes, what does the following show:
                                          trace(UserInput.length,this)
                                          trace(i,this["tf"_"+i])
                                          • 18. Re: Newbie: Comparing Arrays
                                            donalall Level 2
                                            As mentioned previously:
                                            1. The Push code is the Click handler function - only two functions: Main, ClickHandler.
                                            (User clicks Submit button to check answers)
                                            function.buttonClickHandler(event:MouseEvent):void
                                            2. UserInput is defined in the Main class:
                                            • 19. Re: Newbie: Comparing Arrays
                                              i don't know what you're calling your Main class.
                                              but all the code you've been showing should be in the same class or you have a scope problem.
                                              if all your code is in the same class, what do those trace() functions reveal?
                                              • 20. Re: Newbie: Comparing Arrays
                                                donalall Level 2
                                                My class is called "Main_questions".
                                                    public dynamic class Main_questions extends MovieClip
                                                The class consists of two functions:
                                                1. public function Main_questions():void
                                                2. function buttonClickHandler(event:MouseEvent):void
                                                UserInput is defined in the "Main_questions" class:
                                                The trace functions:
                                                (trace(UserInput.length,this)
                                                Return these:
                                                0 [object global]
                                                0 undefined
                                                    at MethodInfo-1()
                                                • 21. Re: Newbie: Comparing Arrays
                                                  you have more than one problem with that setup.  copy and paste your updated Main_questions class code.
                                                  • 22. Re: Newbie: Comparing Arrays
                                                    Andrei1-bKoviI Level 6
                                                    Conceptually, this kind of applications should have entities that supplies data (data provider) and links visuals to the data.
                                                    In your case data is questions/answers while visuals are TextField instances.
                                                    I would strongly advise against using dynamic classes (that allows for adding properties dynamically at runtime via associative array notation), especially in this kind of cases. While utilizing dynamic features sometimes is useful, in the majority of cases it present major headaches down the road and is very inefficient from performance standpoint.
                                                    Below is a fully functional class that accomplishes what you are looking for. Role of data provider is accomplished by the questions array. This is an array of objects that accomplish the linkages between questions, answers and TextFields at both configuration and user interaction phases. Read comments.
                                                    All features are dynamic except I use name “checkButton” for the submit button.
                                                    Theoretically this application asks for at least two more classes but, because you stated that you are new to AS3 – this is a sufficient beginning.
                                                    At last, you should get into a habit to declare as few variables as possible and NEVER declare variables in the loops. Declaring variables inside loop bodies is a pretty bad practice.
                                                    package
                                                        import flash.events.MouseEvent;
                                                        import flash.text.TextFieldAutoSize;
                                                        import flash.text.TextFieldType;
                                                            // use single object that acts as a data provider and links questions, answers and runtime object
                                                            private var questions:Array;
                                                            private var textFormat:TextFormat = new TextFormat("Verdana", 9);
                                                            // correct feedback format
                                                            private var correctTF:TextFormat = new TextFormat("Verdana", 9, 0x008000);
                                                            // incorrect feedback format
                                                            private var incorrectTF:TextFormat = new TextFormat("Verdana", 9, 0xDF0000);
        init();
                                                            private function init():void
        initData();
        drawQuestions();
                                                             * This method inititate data and populates it with questions/answers
                                                            private function initData():void
        questions = [];
        // questions
        var question:Array = ["What is the Capital of Ireland?", "What is the Capital of France?", "What is the Capital of Spain?"];
        // answers
        var answer:Array = ["Dublin", "Paris", "Madrid"];
        for (var i:int = 0; i < question.length; i++) {
        // push new object into questions array - this uses literal object instantiation notation {}
        questions.push( { question: question[i], answer: answer[i] } );
                                                             * This method draws text fields and adds them to their correcponding objects
                                                            private function drawQuestions():void
        // use/recycle the same variable - it is more efficient
        var textField:TextField;
        // var to control x positions
        var nextX:Number = 30;
        // var to control y position
        var nextY:Number = 0;
        // loop through questions and create textfileds
        // for each loop is faster than for loop
        // on each loop iteration object element is used from appropriate position on the array
        for each(var q:Object in questions) {
        // CREATE QUESTION TextField
        textField = new TextField();
        textField.defaultTextFormat = textFormat;
        textField.width = 300;
        textField.height = 20;
        textField.x = nextX;
        textField.y = nextY;
        // get question text from the object in questions array
        // ordinal inserted based on the index of question in the array
        textField.text = (questions.indexOf(q) + 1) + ". " + q.question;
        // change nextX
        nextX += textField.width;
        // add field to display list
        addChild(textField);
        // add text field to the object for future linkage to answer
        // this step is optional because actual answer string will be used
        q.questionText = textField;
        // CREATE ANSWER input field
        // note - the same variable textField is used again - NOT the same instance but different instance of THE SAME variable
        textField.border = true;
        textField.width = 200;
        textField.type = TextFieldType.INPUT;
        textField.x = 30;
        // change nextX to accomodate feedback TextField
        q.answerText = textField;
        // CREATE FEEDBACK field
        // again - use the same textField variable to create new instances
        textField.defaultTextFormat = correctTF;
        textField.width = 100;
        textField.x = nextX + 10;
        // add feedback field to the object for linkage to question
        q.feedback = textField;
        // reset positions defaults for the next loop iteration
        nextX = 30;
        nextY += textField.height + 10;
        // assuming that button name is checkButton
        checkButton.addEventListener(MouseEvent.CLICK, buttonClickHandler);
                                                            private function buttonClickHandler(e:MouseEvent):void
        // loop through the objects in questions array and compare answers
        // remove spaces from answers in case user types the in the beginning and the end
        q.answerText.text = String(q.answerText.text).replace(/^\s+|\s+$/, "");
        // compare answers in lower cases
        if (q.answer.toLowerCase() == q.answerText.text.toLowerCase()) {
        TextField(q.feedback).text = "correct";
        TextField(q.feedback).setTextFormat(correctTF);
        else {
        TextField(q.feedback).text = "incorrect!";
        TextField(q.feedback).setTextFormat(incorrectTF);
                                                    • 23. Re: Newbie: Comparing Arrays
                                                      donalall Level 2
                                                      Hi Andrei1,
                                                      Yes this is exactly what I was looking for. Thanks a lot!
                                                      • 24. Re: Newbie: Comparing Arrays
                                                        While waiting for Godot,  I decided to show a more OOP approach to your application. It may be a bit difficult to digest at first, but if you have time and desire – look into what is happening and how things work together in the classes below.
                                                        To test – just put all the classes into the same directory as you FLA and make MainQuestions the document class.
                                                        I split functionality into 5 different classes. One of the OOP principals are to make objects very specialized. This approach presents with much better scalability.
                                                        Some of the highlights:
                                                        1. Document class became very small and it does only two things – places visuals on display list and monitors how user interacts with the button. Technically even these two aspects shouldbe delegated to another class but from illustration standpoint it is not very relvant.
                                                        2. Data is separated into a special class QuestionsData. It may not be apparent at first but this way you can get data different ways and not change a bit of other code that uses this data. For example, in the future you may want to decide to load data at runtime as XML. Still – your application will function the same way despite the fact that data acquisition, parsing and storage change.
                                                        3. I introduced shuffling capabilities in the QuestionsData class to randomize questions – it feels more natural for quizzes.
                                                        4. QuestionLine class is a display object that contains all visuals that pertain to a single question. Note how data is used. Also this class takes care of user entry validation.
                                                        5. Note that because of QuestionLine class, QuestionsContainer class doesn’t have to deal with specifics of question related visuals in depth. QuestionsContainer just creates QuestionLine instances and redistributes data. See init() method of QuestionsContainer.
                                                        6. QuestionTextFiled class. It feels a touch as an overkill but this class allows for unification of some shared functionality between TextFields that are used in QuestionLine. As a result – there is less coding on QuestionLine level.
                                                        There are some other tricks of the trade in the code but they are secondary.
                                                        Class MainQuestions - document class
                                                        package
                                                            public class MainQuestions extends Sprite
        // container that displays questions
        private var container:QuestionsContainer;
        public function MainQuestions():void
        init();
        // instnatiate container
        container = new QuestionsContainer(new QuestionsData());
        addChild(container);
        container.x = container.y = 30;
        // reposition button to the bottom right
        checkButton.x = container.x + container.width - checkButton.width;
        checkButton.y = container.y + container.height + 10;
        container.checkAnswers();
                                                        Class QuestionsData
                                                        package
                                                            public class QuestionsData extends Object
        public var questions:Array;
        public function QuestionsData()
        init();
        // array of questions
        var q:Array = ["What is the Capital of Ireland?", "What is the Capital of France?", "What is the Capital of Spain?", "What is the Capital of Malaysia?", "What is the Capital of New York?", "What is the Capital of California?"];
        // array of answers
        var a:Array = ["Dublin", "Paris", "Madrid", "Kuala Lumpur", "Albany", "Sacramento"];
        questions = [];
        // populate array with objects that link questions and answers
        for (var i:int = 0; i < q.length; i++)
        questions.push({question: q[i], answer: a[i]});
        // randomize
        shuffle();
        * Randomizes questions
        public function shuffle():void
        var value:Object;
        var random:int = 0;
        var i:int = questions.length;
        while (i--)
        random = Math.random() * (i + 1);
        value = questions[random];
        questions[random] = questions[i];
        questions[i] = value;
                                                        Class QuestionLine
                                                        package
                                                            public class QuestionLine extends Sprite
        // text fields
        private var question:QuestionTextFiled, answer:QuestionTextFiled, feedback:QuestionTextFiled;
        // text formats
        private var correctFormat:TextFormat = new TextFormat("Verdana", 9, 0x008000);
        private var incorrectFormat:TextFormat = new TextFormat("Verdana", 9, 0xDF0000);
        // x gap between fields
        private var gap:Number = 10;
        // related to question data
        private var data:Object;
        // question ordinal
        private var index:int = 0;
        // row background colors
        private var rowColors:Array = [0xE8E8E8, 0xFFFFFF];
        // internal padding
        private var padding:Number = 4;
        public function QuestionLine(data:Object, index:int)
        this.data = data;
        this.index = index;
        init();
        question = new QuestionTextFiled();
        answer = new QuestionTextFiled();
        feedback = new QuestionTextFiled();
        question.x = padding;
        question.y = answer.y = feedback.y = padding;
        answer.width = 150
        feedback.width = 60;
        question.autoSize = TextFieldAutoSize.LEFT;
        question.text = String(index + 1) + ". " + data.question;
        answer.type = TextFieldType.INPUT;
        addChild(question);
        addChild(answer);
        addChild(feedback);
        * Provides width of the question field - used for even alignment of
        * textfields in other instances.
        public function get questionWidth():Number
        return question.width;
        * Used to even up fields
        public function set questionWidth(value:Number):void
        // reset autosize so that we can set precise width
        question.autoSize = TextFieldAutoSize.NONE;
        question.width = value;
        // reposition other fields to accomodate passed value
        answer.x = question.x + question.width + gap;
        feedback.x = answer.x + answer.width + gap;
        // draw background based on whether index is odd or even
        graphics.beginFill(rowColors[index % 2]);
        graphics.drawRect(0, 0, width + padding * 2, height + padding * 2);
        // draw buttom line - mainly for the cases when background is white
        // so there is always line that separates the instance visually
        graphics.lineStyle(1, rowColors[1 - index % 2]);
        graphics.moveTo(0, height);
        graphics.lineTo(width, height);
        * Validates user entry and compare entry with the correct answer
        public function checkAnswer():void
        // validate entries
        // remove leading and double spaces
        answer.text = answer.text.replace(/^\s+|\s+$/, "").replace(/\s{2,}/g, " ");
        if (answer.text.toLowerCase() == data.answer.toLowerCase())
        feedback.text = "correct";
        feedback.setTextFormat(correctFormat);
        // make it proper
        answer.text = data.answer;
        else
        feedback.text = "incorrect!";
        feedback.setTextFormat(incorrectFormat);
                                                        Class QuestionsContainer
                                                        package
                                                            public class QuestionsContainer extends Sprite
        private var data:QuestionsData;
        // array of question lines
        private var qLines:Array;
        // maximum width of question field among all question lines used
        private var maxQWidth:Number = 0;
        public function QuestionsContainer(data:QuestionsData)
        this.data = data;
        init();
        // instance of question line that is reused
        var qLine:QuestionLine;
        qLines = [];
        for (var i:int = 0; i < data.questions.length; i++)
        qLine = new QuestionLine(data.questions[i], i);
        // add line to array for further processing
        qLines.push(qLine);
        // grab width if it is the largest one
        maxQWidth = Math.max(maxQWidth, qLine.questionWidth);
        // now that we know the widest line - we can place objects on display list
        placeQuestion();
        * Places question lines on display list and sets largest width for even alignment
        private function placeQuestion():void
        // vertical distance between questions
        var gap = 6;
        // used to set y
        for each (var q:QuestionLine in qLines)
        addChild(q);
        q.questionWidth = maxQWidth;
        q.y = nextY;
        nextY += q.height;
        public function checkAnswers():void
        // loop through the lines and invoke answer checking on them
        q.checkAnswer();
                                                        Class QuestionTextFiled
                                                        package
                                                            public class QuestionTextFiled extends TextField
        private var defaultFormat:TextFormat = new TextFormat("Verdana", 9);
        public function QuestionTextFiled()
        init();
        defaultTextFormat = defaultFormat;
        height = Number(defaultFormat.size) * 2;
        multiline = wordWrap = false;
        * Overrides default behavior and adds border/background
        override public function set type(value:String):void
        super.type = value;
        border = true;
        borderColor = 0xC0C0C0;
        background = true;
                                                        • 25. Re: Newbie: Comparing Arrays
                                                          donalall Level 2
                                                          Hi Andrei1,
                                                          Thanks for the multiple classes example. A little too advanced for me at this stage, but will certainly use it as my AS3 knowledge increases.
                                                          I just have two further queries for you.
                                                          1. CHECKBUTTON
                                                          In your "1 class" example I was able to add a "DrawCheckButton" function to draw the button using only AS3 code. How would i do this in your multiple class example?
                                                          Function: drawcheckButton:
                                                          private function drawcheckButton():void
        // CREATE & ADD "SUBMIT" BUTTON
        checkButton = new Sprite(); //Create a new instance of a Sprite to act as the button graphic.
        checkButton.graphics.beginFill(0xFFCC00); //Set the color of the button graphic.
        checkButton.graphics.drawRect(0,0,100,50); //Set X,Y, Width, & Height of button graphic.
        checkButton.graphics.endFill(); //Apply the fill
        checkButton.x = 300;
        checkButton.y = 300;
        checkButton.useHandCursor = true; //Add useHandCursor, buttonMode, & mouseChildren if required
        checkButton.buttonMode = true;
        checkButton.mouseChildren = false;
        this.addChild(checkButton);  //Add Button Sprite to stage
        textLabel.text = "Submit!";
        textLabel.x = 20;
        textLabel.y = 10;
        textLabel.selectable = false;
        checkButton.addChild(textLabel)
                                                          2. SCORE
                                                          I was able to add  a score to the "buttonClickHandler" function in your "1 class" example.
                                                          By using two variables - "TotalCorrectscore" and "Score".
                                                          Is this the right way to do it? (maybe i could have used existing variables)
                                                          Can i add the code below in the same way in the multiple classes example as well.
                                                          The bold text is the text i added to your code.
                                                          Function: buttonClickHandler
        var TotalCorrectscore:Number = 0;  // Number of correct answers.
        // remove spaces from answers in case user types in the beginning & the end
        TotalCorrectscore=TotalCorrectscore+1  // Adds 1 to correct answer score.
        else {
        var Score:TextField = new TextField();
        Score.defaultTextFormat = textFormat;
        if (TotalCorrectscore == 1) {  // Score feedback says ".   answered 1 question...(question is singular)"
        Score.text = "Score: "+((TotalCorrectscore/questions.length)*100)+" %. (1 question correct out of "+(questions.length)+" questions)";
        else {   // Score feedback says ".   answered X questions... (questions is pural)"
        Score.text = "Score: "+((TotalCorrectscore/questions.length)*100)+" %. ("+TotalCorrectscore+" questions correct out of "+(questions.length)+" questions)";
        Score.border = false;
        Score.width = 400;
        Score.height = 20;
        Score.x = 200;
        Score.y = 250;
        addChild(Score);
                                                          • 26. Re: Newbie: Comparing Arrays
                                                            As far as the original class goes - below is one of the ways to implement what you asked about.
                                                            I don't have time to do the same in the multiple classes implementation though. I trust you can do it yourself.
                                                            One piece of advice.
                                                            Conventionally, Classes are named starting with Upper case. It is prudent to name all variables and methods starting with lower case - this improves code readability. In your instance variable "Score" should be "score."
                                                            Read comments.
                                                            package
        private var checkButton:Sprite;
        // text field that displays score feedback
        private var scoreFeedback:TextField;
        // answers score value
        private var score:int = 0;
        init();
        drawcheckButton();
        initData();
        drawQuestions();
        questions = [];
        // questions
        var question:Array = ["What is the Capital of Ireland?", "What is the Capital of France?", "What is the Capital of Spain?", "What is the Capital of Malaysia?", "What is the Capital of New York?", "What is the Capital of California?"];
        // answers
        var answer:Array = ["Dublin", "Paris", "Madrid", "Kuala Lumpur", "Albany", "Sacramento"];
        questions.push({question: question[i], answer: answer[i]});
        scoreFeedback = new TextField();
        scoreFeedback.defaultTextFormat = textFormat;
        scoreFeedback.autoSize = "left";
        scoreFeedback.width = 400;
        scoreFeedback.height = 20;
        addChild(scoreFeedback);
        scoreFeedback.x = scoreFeedback.y = 30;
        var nextX:Number = scoreFeedback.x;
        var nextY:Number = scoreFeedback.y + scoreFeedback.height + 20;
        for each (var q:Object in questions)
        // change nextX
        textField.x = 30;
        nextX = 30;
        checkButton.x = textField.x + textField.width;
        checkButton.y = textField.y + textField.height + 6;
        checkButton.graphics.drawRect(0, 0, 100, 50); //Set X,Y, Width, & Height of button graphic.
        var textLabel:TextField = new TextField();
        textLabel.x = 20;
        textLabel.y = 10;
        // reset score to 0
        score = 0;
        // increment score by 1
        score++;
        else
        // display score feedback
        // note literal conditional syntax (score != 1 ? "s" : "") that adds "s" for plurals
        scoreFeedback.text = "Score: " + Math.round(score * 100 / questions.length) + "% (" + score + " question" + (score != 1 ? "s" : "") + " correct out of " + questions.length + " questions.)";
                                                            • 27. Re: Newbie: Comparing Arrays
                                                              A little improvement.
                                                              Button should be a separate class. See CustomButton class below. Also class Main_questions implements this button (also attached to this message)
                                                              package
        public class CustomButton extends Sprite
        private var label:String;
        // off state
        private var stateOff:Sprite;
        // mouse over state
        private var stateOver:Sprite;
        public function CustomButton(label:String = "Label")
        this.label = label;
        init();
        stateOff = drawState(0xFFCC00, 0xBB5E00);
        stateOver = drawState(0xFFE991, 0x8C4600);
        addChild(stateOver);
        addChild(stateOff);
        stateOver.visible = false;
        buttonMode = useHandCursor = true;
        addEventListener(MouseEvent.MOUSE_OVER, onInteraction);
        addEventListener(MouseEvent.MOUSE_OUT, onInteraction);
        private function onInteraction(e:MouseEvent):void
        stateOff.visible = e.type == MouseEvent.MOUSE_OUT;
        stateOver.visible = e.type == MouseEvent.MOUSE_OVER;
        private function drawState(fillColor:uint, color:uint):Sprite
        // horizontal padding
        var hPadding:Number = 20;
        // vertical padding
        var vPadding:Number = 6;
        var labelText:TextField = new TextField();
        labelText.defaultTextFormat = new TextFormat("Verdana", 10, color);
        labelText.multiline = labelText.wordWrap = false;
        labelText.autoSize = "left";
        labelText.text = label;
        labelText.x = hPadding * .5;
        labelText.y = vPadding * .5;
        var s:Sprite = new Sprite();
        s.graphics.beginFill(fillColor);
        s.graphics.drawRoundRect(0, 0, labelText.width + hPadding, labelText.height + vPadding, 5);
        s.graphics.endFill();
        s.addChild(labelText);
        return s;
                                                              package
        init();
        drawcheckButton();
        initData();
        drawQuestions();
        questions = [];
        // questions
        // answers
        // change nextX
        textField.x = 30;
        nextX = 30;
        checkButton = new CustomButton("Submit"); //Create a new instance of a Sprite to act as the button graphic.
        // reset score to 0
        score = 0;
        score++;
        else
                                                              • 28. Re: Newbie: Comparing Arrays
        Here are updated classes that use new CustomButton class and visualize score.
        Note that QuestionLine.checkAnswer() method now returns score for each line so that it can be used in QuestionsContainer.checkAnswers() method.
        Classes that are not posted did not change.
        package
        private var checkButton:CustomButton;
        init();
        checkButton.y = container.y + container.height + 20;
        package
        private var scoreFeedback:QuestionTextFiled;
        this.data = data;
        init();
        // draw score
        scoreFeedback = new QuestionTextFiled();
        //scoreFeedback.autoSize = "left";
        qLines = [];
        qLines.push(qLine);
        placeQuestion();
        var gap:Number = 6;
        // used to set y
        var nextY:Number = scoreFeedback.height + gap;
        addChild(q);
        q.y = nextY;
        nextY += q.height;
        score = 0;
        // read score of each line - method returns int
        score += q.checkAnswer();
        scoreFeedback.text = "Score: " + Math.round(score * 100 / data.questions.length) + "% (" + score + " question" + (score != 1 ? "s" : "") + " correct out of " + data.questions.length + " questions.)";
        package
        // text fields
        // text formats
        // question ordinal
        // internal padding
        this.data = data;
        this.index = index;
        init();
        answer.width = 150
        addChild(question);
        addChild(answer);
        addChild(feedback);
        public function checkAnswer():int
        // validate entries
        // make it proper
        return 1;
        else
        return 0;
        • 29. Re: Newbie: Comparing Arrays
        athniel Level 1
        Hi Andrei1
        I tried this code (hoping it be useful for problem I'm having with flashcards arrays)  but even though I have made a button called checkButton - name, Class and instance  - I get this error:
        "1046: Typwewas not found or was not a compile-time constant: checkButton".
        I even added:
        import flash.display.SimpleButton;
        to the code, but it didn't help. What have I done wrong?Any advice much appreciated. Thanks .
        • 30. Re: Newbie: Comparing Arrays
        In my post No 27 there is a Class CustomButton. You must place this class into the same directory as your FLA and all other classes.
        • 31. Re: Newbie: Comparing Arrays
        athniel Level 1
        Thanks. I removed my button and used your updated classes - all seems to be fine now.
        • 32. Re: Newbie: Comparing Arrays
        donalall Level 2
        Hi Andrei1,
        Sorry for the delay in responding i was away.
        Thanks very much for the updates to the code and for your time.
        I'll put all this to good use.
        • 33. Re: Newbie: Comparing Arrays
        You are welcome.
