If you have a ColdFusion template which calls another
template within a CFMODULE tag, can you later access variables set
in the CFMODULE tag from the caller template? I am aware of the
CALLER scope within CFMODULES however, I was wondering if there is
a scope to go the other direction so templates can get the
variables within the cfmodule?
For example:
---SecondPage.cfm---
<CFSET Apples="yes">
---End---
---FirstPage.cfm---
<CFMODULE template="secondpage.cfm">
The value for apples is:
<CFOUTPUT>#[scope].Apples#</CFOUTPUT>
> caller template? I am aware of the CALLER scope within
> was wondering if there is a scope to go the other
> get the variables within the cfmodule?
<!--- in module template --->
<cfset caller.apples = "yes">
<!--- in calling template --->
<cfoutput>#variables.apples#</cfoutput>
I am aware of the CALLER scope to send data from the module
back to the calling template. However, what I want is to be able to
reference variables within the module from within the calling
template.
It seems like if we could name the instance of the module, we
should be able to reference these variables using the named
instance before the variable name. like
#MyModuleName.VariableName#.
Perhaps there is no way to do this in the current verion of
Coldfusion, or perhaps there is a variable scope I am unaware
of?
The closest thing to what you want is to put the values in
the caller
scope. That said, you should really NOT want to be doing what
you're doing
anyhow, as the calling code should not "interested" in the
vagaries of what
goes on in the module. It's te whole idea of using modules...
abstracting/hiding processing from the calling code.
I am trying to create CFMODULE pages that may be called from
either a CFMODULE tag or a CFINCLUDE. There are some cases where I
want to protect variable names and others where it is not as
important.
I was hoping to eliminate the need for setting variables to
the CALLER scope within the cfmodule. If there would be a way for
me to access the variables in the module from the calling template
it would give me more flexibility.
Perhaps the best way to do this is to have the module page
check to see if indeed it is a module first and then through a
series of CFIF statements set variables normally or via the caller
scope.
to the CALLER scope
Given this is the way to achieve what you want to do, why do
you want to
"eliminate" it?
There is no "special scope". All the local memory from the
module is
released when it finishes. To effect what you want to do, you
need to set
values in a scope other than the local memory scope of the
module. The
most appropriate is in the variables scope of the calling
code, which you
do via the caller scope. That's it. That's the answer.
If you think it's NOT the answer, it would really help your
cause if you
could explain *what you're actually trying to achieve*, and
why you don't
want to use the caller scope.
Bottom Line: There is no way to access variables that are set
in a CFMODULE. You must use the CALLER scope to transfer variable
values to the calling template.
