This question was posted in response to the following article: http://help.adobe.com/en_US/FlashPlayer/LSM/WS6aa5ec234ff3f285139dc56112e3786b68c-7ff5.html
Would this help with my system so that AVG would not block my ability to use my updated version of the flash player?
No, I do not believe this would be relevant in the AVG case unless the website you were visiting specifically uses this feature. Can you give me more details on why you suspect AVG is interfering with playback?
Chris
Every time I get to a place on any site, (Yahoo News) the video says that I need to install a Flash Drive and I have Adobe"s latest version installed. I check list of Security on computer and it tells me that AVG has disabled the Video because of a security threat to my Browser.
Wyatt--
What browser are you using? When you go to the following page, does it tell you which version you have installed?
http://kb2.adobe.com/cps/155/tn_15507.html
Chris
Thank -you and I found out That Google Chrome just installed was an additive to the situation.
Wyatt--
My webcam's mic works great through comp tests and soundcard tests, but when I use it for tinychat, the mic stays silent even though I allow it and can see the color coded bar go up and down. It was recommended to me that flash was the problem. I dunno what to do.
Hilary,
What version of Flash Player do you have installed?
http://helpx.adobe.com/flash-player/kb/find-version-flash-player.html
Chris
The very latest one. The 11.2 version or something like that.
What browser and operating system are you using? Also, what webcamera do you have installed?
Microsoft windows xp professional, sp3. I have a GE camera minicam pro. However, I have gotten other webcams and they have had the exact same problem. I am not sure if it's a site specific problem, although it can't be because everyone else's works.
Does your computer use a proxy server to connect to the internet? If so, this might be the problem. In this case, tinychat needs to implement RTMPT, they might be using just RTMP instead which does not support proxy settings.
To verify your microphone is working in Flash player, we'll need to do a local test through the Flash settings dialog. You can access the Flash settings dialog by right clicking on most Flash content. For example, right click on the Global Privacy Settings panel and click the Settings menu item.
Then click the microphone tab and you should see the volume level move as you start talking. If this works, then Flash should be able to use your mic properly given the proper network connections.
Where you able to resolve the mic problems? I'm also wondering if this could be related to the following garbled sound output bug we have against TinyChat. If so, could take a minute and cast a vote to get this issue fixed?
Chris
Chris, I was able to see the mic work in flash, but when I test my mic in flash it is choppy and weird sounding: distorted. When I test my mic in windows test, it sounds smooth and responsive. So I have no idea what the HELL is going on... I also have another bug with adobe flash in youtube.... Smh..
When you head the choppy / weird sounding issue with the mic, was that in TinyChat? If so, then it's probably related to the bug I mentioned.
What's going on with YouTube?
Chris, no. When I tested my mic in adobe flash on my computer when beginning a video, it was choppy and broken.
As far as youtube is concerned, when I full screen mode a playlist, the player plays only every other video and not videos in synchronized order the way I set my playlist up. However, when I take it out of fullscreen, it then plays correctly. Someone needs to fix that problem ASAP.
Thanks for the feedback on the microphone. I believe you should report the playlist problem to YouTube, as it's most likely their issue.
ZASHTO PO VREME NA GLEDANE NA KLIP PC MI ZABIVA?
hi i have installed the new adobe player 11 on my pc and now i cant stream videos or fb games and youtube videos on my Firefox can you help me thanks.
i have tried the fire fox maintenance service from fire fox website and nothing worked
Mohamad - Can you try the troubleshooting steps listed in this FAQ and let us know if it helps?
I have the most current version of Flash but have lost internet sounds. The media player on my computer works but I have lost sound on all browsers. What could the issue be?
Estou com o mesmo problemas. Alguns vÃdeos do youtube e todas as tvs online estão sem áudio. Já testei quatro navegadores e em todos o problema é o mesmo. Google Chrome, Explorer, Opera e Firefox. Versão nova do Adobe Flash Palyer 11.
Meu windows é o vista home premium
I had similair problem and it ended up being the main sound in programs and features.
When they added several different uaudio players on your system.
ne would play and the other would kick the one playing right off not warrniongs. UnAmerican
Chrome, Windows. When user open my application (this app used p2p) and click Allow on this Peer-Assisted popap (select "remember") http://screencast.com/t/zCAcuafni9 this site(flashstudio.com.ua) doesnt added on Global Settings to this list http://screencast.com/t/zCAcuafni9 so user need click every time Allow... (another app with p2p worked fine)
