Hi all,
RoboHelp produces an Epub output with the generated TOC page at the end of the book. We strongly prefer having the TOC at the begin.
It is possible of course to decompile the file and change the order each time, but maybe someone knows a permanent solution? Presumably it is possible to change this somewhere in the XSL files that Robohelp uses for creating the output.
Robert
You can always modify the ePub file with Sigil: an open source WYSIWYG ebook editor. (code.google.com/p/sigil/)
As for the RoboHelp SSL, that's an interesting question. I haven't done much with that SSL, but the generation may be embedded in a DLL. If you can locate the XSL templates, you may be able to modify the RH behaviour.
Greet,
Willam
