Difference between compiling locally and on the server with FDS
Avatar
Level 1
I am doing soming very basic testing with remote Java objects
and I am finding that if I create a FDS project and compile on the
server the code runs, if I create a FDS project and compile locally
it gives me the following error :
[RPC Fault faultString="Send failed"
faultCode="Client.Error.MessageSend"
faultDetail="Channel.Connect.Failed error
NetConnection.Call.Failed: HTTP: Failed"]
what gives?
The compiler in Flex Builder string is :
-services "C:\Archivos de programa\Apache Software
Foundation\Tomcat
5.5\webapps\flex\WEB-INF\flex\services-config.xml" -locale en_US
Any insights?
David
Avatar
Employee
Hi David,
The FDS server automatically knows the context root of your
application
For FlexBuilder, you need to provide the context root as a
compiler argument
-context-root /flex (or whatever your context root is)
peter
Avatar
Former Community Member
I am also facing an issue regarding compiling mxml using
remote objects using flex sdk. The error I am getting is
faultDetail="Channel.Security.Error error Error #2048: Security
sandbox violation:
http://localhost:9080/iReports/flexFiles/mxml/AdminServices.swf
cannot load data from
http://localhost:9080iReports/messagebroker/amf."
Can u help me?
Cheree
Avatar
Level 1
Hi Cheree,
You really should post this as a new qustion.
I noticed that you error message has
http://localhost:9080iReports/..."
instead of
http://localhost:9080/iReports/...
You are missing a / in the address location of the service after
9080 (ie should be 9080/iReports not 9080iReports. If this sitll
doesn´t work you should repost your message as a new question.
Regards
David
Avatar
Hi David,
Thanks for replying... What you suggested was absolutely
correct. Actually, I was giving
-context-root=\iReports, but what was needed was
-context-root=/iReports.
Thanks again,
Cheree
