cs6 install error messages
itsjims Sep 19, 2012 12:14 PMMacBook Pro 17-inch, Early 2011,
2.3 GHz Intel Core i7
16 GB 1333 MHz DDR3
AMD Radeon HD 6750M 1024 MB
Mac OS X Lion 10.7.4
First as for experience I am a Photographer, I have been working with PS since PS4, that said I know enough to get around for most tasks, but I don't call myself a tech'ie.
Smart enought to get out of most problems, but also smart enought/not to cause my own problems..
Before I go to customer support I thought I'd try here first. I have run the install twice now the first error summary is here
Exit Code: 6
Please see specific errors and warnings below for troubleshooting. For example, ERROR: DF019, DF037 ... WARNING: DW063 ...
-------------------------------------- Summary --------------------------------------
- 0 fatal error(s), 232 error(s), 302 warning(s)
----------- Payload: {554A7BA9-8879-496E-BC3D-93650613DDE5} Adobe Photoshop CS6 Support_13.0.1_AdobePhotoshop13-Support 13.0.1.0 -----------
ERROR: DF037: Unable to delete directory "/Applications/Adobe/AdobePatchFiles"(Seq 4)
WARNING: DW063: Command ARKDeleteDirectoryCommand failed.(Seq 4)
----------- Payload: {C975B8D6-9B6F-4A95-A475-CFB14C3C33D9} Adobe Extension Manager CS6_6.0.1_AdobeExtensionManager6.0All 6.0.1.0 -----------
WARNING: DW063: Command ARKPatchCommand failed.(Seq 1)
WARNING: DW063: Command ARKPatchCommand failed.(Seq 3)
WARNING: DW063: Command ARKPatchCommand failed.(Seq 5)
WARNING: DW063: Command ARKPatchCommand failed.(Seq 7)
WARNING: DW063: Command ARKPatchCommand failed.(Seq 8)
And skipping to the end as it is rather long, if the 2 or 300 errors and warnings are helpful I can send.
WARNING: DW063: Command ARKPatchCommand failed.(Seq 413)
ERROR: DF019: Unable to locate file to patch at "/Applications/Adobe Photoshop CS6/Adobe Photoshop CS6.app/Contents/Required/Plug-Ins/Extensions/Enable Async IO.plugin/Contents/MacOS/Enable Async IO"(Seq 415)
WARNING: DW063: Command ARKPatchCommand failed.(Seq 415)
ERROR: DF019: Unable to locate file to patch at "/Applications/Adobe Photoshop CS6/Adobe Photoshop CS6.app/Contents/Required/Plug-Ins/Import-Export/EazelAcquire.plugin/Contents/Info.plist" (Seq 417)
WARNING: DW063: Command ARKPatchCommand failed.(Seq 417)
ERROR: DF019: Unable to locate file to patch at "/Applications/Adobe Photoshop CS6/Adobe Photoshop CS6.app/Contents/Frameworks/AdobeCrashReporter.framework/required/Adobe Crash Reporter.app/Contents/Resources/it.lproj/InfoPlist.strings"(Seq 419)
WARNING: DW063: Command ARKPatchCommand failed.(Seq 419)
ERROR: DF019: Unable to locate file to patch at "/Applications/Adobe Photoshop CS6/Adobe Photoshop CS6.app/Contents/Frameworks/AdobeCrashReporter.framework/required/Adobe Crash Reporter.app/Contents/Resources/es.lproj/Localizable.strings"(Seq 421)
WARNING: DW063: Command ARKPatchCommand failed.(Seq 421)
ERROR: DF019: Unable to locate file to patch at "/Applications/Adobe Photoshop CS6/Adobe Photoshop CS6.app/Contents/Resources/Adobe Photoshop CS6.rsrc"(Seq 423)
WARNING: DW063: Command ARKPatchCommand failed.(Seq 423)
----------- Payload: {9124DF4E-617D-486B-A970-8FA632244F24} Adobe Photoshop CS6 Core 13.0.0.0 -----------
ERROR: DF024: Unable to preserve original file at "/Applications/Adobe Extension Manager CS6/Adobe Photoshop CS6/Adobe Photoshop CS6.app/Contents/Frameworks/AdobeCrashReporter.framework/AdobeCrashReporter" (Seq 94)
ERROR: DW063: Command ARKDeleteFileCommand failed.(Seq 94)
ERROR: DW050: The following payload errors were found during install:
ERROR: DW050: - Adobe Photoshop CS6 Core: Install failed
Reading this I deleted this AdobePatchFile, and ran the installer again.
This is the error summary after the second run of the installer, I've reached the end of my thinking, maybe best so.
Exit Code: 6
Please see specific errors and warnings below for troubleshooting. For example, ERROR: DF024, DW063 ...
- 0 fatal error(s), 3 error(s), 0 warning(s)
Any assistance would be very helpful or should I just ring up Adobe Support.
