Hi WriterBen and Colum
Ben, Colum correctly told you how to accomplish this. But I
have one little tidbit to add.
If you insert more than one "See Also" control on a page, you
will need to be careful about what you do with the script. RoboHelp
HTML normally names the first instance "SeeAlso". But subsequent
instances are named differently. And the exact name used will
depend on how that control is inserted.
If you are inserting them via the menu - Insert > See
Also...
The second will normally be named OBJECT1
The third will normally be named OBJECT2 and so on
If you are inserting them via Copy/Paste
The second will normally be named object1
The third will normally be named object2 and so on
I bring this up because JavaScript gets totally persnickety
with these names. Object1, OBJECT1 and object1 are three different
names to JavaScript. So you need to pay close attention to what
they are named and use the correct name when you type the
JavaScript code. javascript:SeeAlso.Click(); then becomes
javascript:OBJECT1.Click(); or javascript:object1.Click();
Happy Friday all... Rick
