When a page of mine is found via google only that single page is shown - not the toc. How can I get the single page to show the toc etc as well?
I'm not sure there is an easy way. A call to your help file needs to call the file entered as the Start Page in your single source layout (e.g. index.htm) to see the TOC. If Google has your individual topic files indexed you will just get the topic. However if you select the "Show Navigation Pane Link in Topic" option in the single source layout you will get a "Show" hyperlink in your topics which will display the TOC, Index and Search when clicked.
Ta for such a prompt reply & thanks for understanding my question. I've enabled the "Show Navigation Pane Link in Topic" option. Would it be possible to replace the 'Show' link with an 'onload' command?
That might be possible via some sort of script but that is getting into an area I know next to nothing about. Sorry.
Try this: http://www.wvanweelden.eu/blog/2012/08/01/always-show-webhelp-navigation-pane
Greet,
Willam
William, as always brilliant. Ta very much.
