Thanks for the reply.
I have had problems using BinaryDecode. It states the input
and output are not the same not matter what I use as the
binaryencoding. I can get a pdf binary object sent to the browser
by using this:
<CFHEADER NAME="Content-Disposition" VALUE="attachment;
filename=#fileNAME#.#fileEXT#">
<CFCONTENT TYPE="*/*"
VARIABLE="#ToBinary(ToBase64(docBINARY))#">
ToBinary nor ToBase64 work on their own (I get an error about
ByteArrays), but they seem to work together. However, now I get a
12 page PDF with 1 blank page and all the other pages generate
errors in the Adobe Reader. I have confirmed that the document
comes up fine in the Java applications that do basically the same
thing, but it is like ColdFusion does not understand the data type.
Unfortunately, our DEV and UAT systems are not exposed for me
to give you access. The Web Service I am consuming will never be
available externally, which is why I am building a CF passthrough
to display the documents to public users. The internal system will
output private contracts, so there are privacy issues related to
opening it up. Our prod deployment is very strict, so I cannot even
put up public pages for testing until all involved sign off on
functionality.
Obviously, the CFDUMP exceeds the text limit, so I cannot
post it either. :(
Edit: Also, I found out that the first byte of object is a
status code. I have parsed that off (why you now see docBINARY),
but I only see this as a square and have not been able to convert
this to the number code I should be getting.
