5 Replies Latest reply: Sep 20, 2012 10:17 PM by Jon-M-Spear RSS
    White Balance Effect
    Petrula Community Member
      CS6 Production Premium Suite
      Win7x64
      Nvidia GForce GTX 470
      Intel i7 930 @2.8GHz
      12 GB memory
      Canon XA10
      Does Premiere have a White Balance effect like Camera Raw which adjusts the white balance Kelvin?
      If not, why not since Camera Raw has one.
      Is there a third party that does?
      Thanks in advance.
        • 1. Re: White Balance Effect
          shooternz Community Member
          Camera Raw by definition is ammenable to that function.
          • 2. Re: White Balance Effect
            Bill Hunt CommunityMVP
            PrPro offers at least three CC Effects, and there are several 3rd party CC plug-ins, like Colorista.
            Remember that with but a very few exceptions, one is not working with RAW files in PrPro. They have already been processed.
            If you have not explored PrPro's CC Effects, I would start with Fast Color Corrector.
            Good luck,
            Hunt
            • 3. Re: White Balance Effect
              wfmc staffer Community Member
              The fast color corrector has a white balance option. Do you include a neutral white item in most shots?
              • 4. Re: White Balance Effect
                I use an Expo Disc to manually set the white balance for the Canon XA10. However, the lighting was suddenly changed while shooting. Unfortunately, the XA10 greys white balance changes while shooting. The speaker would have gone ballistic if I asked her to stop for a moment to change to auto white balance. So I was forced to shoot with a manual white balance setting that looked great before the lighting change but looked awful afterward. Hence, the need to make white balance adjustments in post production.
                • 5. Re: White Balance Effect
                  Jon-M-Spear Community Member
                  Think of it less of white balance at this post stage, more of colour correction.
                  If you're saying that the colour temperature changed, does that mean you have material that is correct?
                  If so, use your that as your master and, using the RGB waveform and vectorscope along with the three way colour corrector, correct your bad material to match the scopes reading of the master.
