1. Re: How to request for more than one plane data (RGB data)?
Chris Cox May 30, 2011 9:58 AM (in response to dheeraj_c)Just set the highplane and lowplane values for the planes you need.
Also, read the SDK - it explains how to do many of these things.
2. Re: How to request for more than one plane data (RGB data)?
Royi A Sep 22, 2012 12:57 PM (in response to Chris Cox)Hi Chris,
I'm having the same problem and I can't find a solution in the SDK.
I look at the following code:
for (int16 plane = 0; plane < gFilterRecord->planes; plane++)
// we want one plane at a time, small memory foot print is good
gFilterRecord->outLoPlane = gFilterRecord->inLoPlane = plane;
gFilterRecord->outHiPlane = gFilterRecord->inHiPlane = plane;
As I understand if I change it into:
gFilterRecord->outLoPlane = gFilterRecord->inLoPlane = 0;
gFilterRecord->outHiPlane = gFilterRecord->inHiPlane = 2;
I should have all 3 channels at once.
Yet when I go to the pointer 'gFilterRecord->inData' / 'gFilterRecord->outData'
I see a NULL pointer.
I'd be happy for a clarification.
Thank You.
3. Re: How to request for more than one plane data (RGB data)?
Tom Ruark Sep 28, 2012 9:36 AM (in response to Royi A)I did the same experiment and it worked for me. I got interleaved RGB values as expected. What did advanceState return as an error code? Are you sure something else was not modified from the original example code? Is your image very large? Give me the info on the rest of the FilterRecord (width, height, mode ).
