Hi. I have a jump to place in ppt hyperlink that was working but now it won't after publish. It does workj within Powerpoint. Could it have something to do with the reporting setup which is set to % of slide views?
Hello,
Welcome to Adobe Forums.
Are you jumping to a specific slide or to a URL ?
Reporting setup is changed when you want to have reporting enable and you want to check for scores in quiz or whether the project is viewed completely.
Can you share your Powerpoint Presentation with us ?(tcssup@adobe.com)
Vikram
Hi. I actually think I figured it out. Deleting and replacing the quiz seems to have worked.
P.S. Can you tell me where on the support site the search bar is for searching discussions by keyword?
Hello,
When you open forums.adobe.com, there is a section "Ask a question" and below that you have the search bar.
On the search bar you use Keywords to search discussion on Adobe Forums.
Vikram
I get it now. txs.
to answer your earlier question, it was jumping to slide within the same presentation. It was working for quite some time, I then made some changes in the quiz and could not get it to work again.
Hello,
Try this :
Copy all the slide of you presentation to a new Presentation and then create your quiz again.
Vikram
can I import the quiz from the previous presentation?
Hello,
Import won't be possible .
Vikram
If that is the case, when is the import quiz from other presention option possible?
Hello,
I will forward this to the concerned team.
Vikram
Hi
You can import the quiz into another presentation as log as you have not copied any of the question slides from one presentatio to another,
It is not recommended to copy paste questions.
Regarding your question can you be more specific from where you have set the hyperlink?
The hyperlinks can be set through
1. the quiz manager for quiz/quiz group/question on pass and fail options
2. through Powerpoint actions and hyperlinks.
Which option did you use
Mahesh
