A new blog has been posted as the part of "ExtendScript of the Week" series :
Vikash
http://blogs.adobe.com/techcomm/2011/10/extendscript-of-the-week-create-a-upgraded-copy-of-book.html
Upgrades a legacy book (& files) to current FM version. Shows how to loop through all files in a book. Also shows how to handle hierarchical books with groups and folders.
Continuing with the "ExtendScript of the Week" series , a new blog has been posted at :
It shows how to delete all the unused formats in a book.
Vikash
Generates a list of imported (by reference) graphics and allows you to edit the list and re-import to fix any unresolved (i.e. missing) graphics at the book level.
This an extendscript to "Close All Files in a Book without Saving" designed to show how to use FrameMaker ESTK to traverse a hierarchical book and perform operations on its components.
Find/Change XRef Format,Conditional Tag,Variables on the body page of the FrameMaker document .
This script demonstrates how to use Extend Script to traverse a document, find Xrefs/Conditional Tags/Variables and then change them or delete them.
http://blogs.adobe.com/techcomm/2011/12/extendscript-of-the-week-import-and-export-variables.html
"...export a list of User Variables in a FrameMaker Book. The list will also show the status that whether the user variables is used or not. After the list has been generated, you can modify the definition of the user variables in the table and the table can be imported back to the book. This will help modifying and deleting user variables at the book level."
http://blogs.adobe.com/techcomm/2011/12/extendscript-of-the-week-externalizing-graphics.html
"...an extendscript utility to convert all the graphics in FM/Book “imported by copy” to “imported by reference”. In this process all graphics imported by copy will be created externally and then imported by reference. These externalize graphics will be created in same directory as source file is."
http://blogs.adobe.com/techcomm/2012/01/extendscript-of-the-week-restore-window.html
"...an extend script which restores the window location, zoom and other display settings available under View menu of the FrameMaker document . This script demonstrates how to use Extend Script to retrieve display specific document properties and apply these settings on other FM document."
"... an extend script which suppresses a specific FM alert which is specified by the user. The script prompts the user to enter the alert string displayed by FM Alert dialog in a text box and then subsequently suppresses the alert when it occurs."
All about using FM's Fcodes to automate small tasks instead of going the API functions route.
Does the extendscript for creating a list of referenced graphics work only with FrameMaker 11? I have FM10 and cannot get the zipped files to open in the FM10 statup folder. This list is exactly what I'm looking for!
AFAIK, these scripts were all written for FM10.
If you're having problems unzipping the file, thenperhaps the file may have been corrupted (or is incomplete) during the download. I believe that 7-zip is used to create the zips, so perhaps some compression options aren't understood by your extraction tool? Do you have permissions to allow the extraction to the FM10 folders?
Thanks for your reply. I was using 7-zip at the time. In any event, I found a different solution that worked fine.
