1. Re: I am unable to log into the Contribute administration panel through Dreamweaver
Dominic Michael Sep 6, 2012 10:59 PM (in response to KristinFl)Sometimes the login window might hidden behind Dreamweaver. Minimize all the open windows one by one and verify whether the login window is hidden behind.
2. Re: I am unable to log into the Contribute administration panel through Dreamweaver
KristinFl Sep 7, 2012 5:20 AM (in response to Dominic Michael)It was hidden in the past but now it is not there at all. I have minimized all windows.
3. Re: I am unable to log into the Contribute administration panel through Dreamweaver
Anit_Kumar Sep 14, 2012 4:05 PM (in response to KristinFl)Please try the following steps:-
- Choose Site > Manage Sites.
- Select your site and Click Edit.
- Select the Servers category.
- Select the server to modify and click the Pencil icon.
- Change you password (set an incorrect password), then click Save.
- In the Site Setup dialog box, expand Advanced Settings, select the Contribute category.
- Click Administer Site in Contribute. It would show you an error message.
Now
- Click on Select the Servers category.
- Change you password (type the correct password), then click Save.
- Click Administer Site in Contribute. It would show you the password login window.
Hope it helps.
4. Re: I am unable to log into the Contribute administration panel through Dreamweaver
KristinFl Sep 14, 2012 10:04 PM (in response to Anit_Kumar)Thanks but no success. I followed your steps but no password login window showed up. I also tried to create a new site and had no success. I am able to administer through Contribute CS5.5 but no longer can administer login through my DW 5.5.
5. Re: I am unable to log into the Contribute administration panel through Dreamweaver
Anit_Kumar Sep 17, 2012 9:05 AM (in response to KristinFl)Contribute must be installed on the same computer as Dreamweaver. Please confirm, if that is the case or not.
Also please let us know the version of Contribute, you are using.
6. Re: I am unable to log into the Contribute administration panel through Dreamweaver
KristinFl Sep 17, 2012 9:26 AM (in response to Anit_Kumar)Yes, Contribute CS4 is installed.
7. Re: I am unable to log into the Contribute administration panel through Dreamweaver
Anit_Kumar Sep 17, 2012 5:52 PM (in response to KristinFl)I have sent a private message to you.
8. Re: I am unable to log into the Contribute administration panel through Dreamweaver
Anit_Kumar Sep 25, 2012 2:21 AM (in response to Anit_Kumar)Can you check that the _mm folder contains a shared settings file with a CSI extension
9. Re: I am unable to log into the Contribute administration panel through Dreamweaver
KristinFl Sep 25, 2012 3:22 AM (in response to Anit_Kumar)Yes, it does.
I have installed Contribute S5.5 and am administering from it now. I never could get DW working.
10. Re: I am unable to log into the Contribute administration panel through Dreamweaver
Gabriel Landes Nov 13, 2012 9:17 AM (in response to KristinFl)I'm seeing the same behavior: after installing CS5.5, clicking "Administer ... " in Dreamweaver no longer triggers the form. Are there any work arounds out there?
11. Re: I am unable to log into the Contribute administration panel through Dreamweaver
Dominic Michael Nov 15, 2012 12:14 AM (in response to Gabriel Landes)When you click on "Administer in Contribute" button in Dreamweaver, to lunch Contribute it will refer to the path "HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\App Paths\Contribute.exe" .
Please make sure that the latest installed version of Contribute location is provided correctly in the PATH key value.
