FYI, the Flash Player Distribution Downloads page (http://www.adobe.com/products/flashplayer/distribution3.html) lists the wrong version 11.4.402.278 (really 11.4.402.267) in the header. I downloaded both the ActiveX and Plugin .MSI files for Windows, listed under Flash Player 11.4.402.278. When editing each .MSI in Orca, it lists the ProductVersion as 11.4.402.267. And, indeed, after installing both appwiz.cpl shows the versions of ProductName = Adobe Flash Player 11 ActiveX and ProductName = Adobe Flash Player 11 Plugin as 11.4.402.267.
This is a bug with the version string in the MSI package. The actual Flash Player active x control does display the correct version (11.4.402.278). Our internal bug number for this issue is 3333545 and we expect this will be fixed in the next release. I've also posted about this here: http://forums.adobe.com/message/4711264#4711264
Chris
Chris
Here is the ProductVersion info from the .MSI I just downloaded using http://download.macromedia.com/get/flashplayer/current/licensing/win/install_flash_player_11_active_...:
