Compiling WebHelp from command line fails with multiple Template Errors
Aug 29, 2012 Aug 29, 2012
I am trying to compile a WebHelp project using the RHCL command. I have RoboHelp HTML 9.0.2.271, running on Windows 7, and the project compiles fine from within the GUI. However, although the first part of the compilation (processing, updating, etc.) works using RHCL, the part where the WebHelp 5.50 template is applied is full of errors. For example:
Template Error: can not resolve macro: WH_LNG_LoadingData
..Template Error: can not resolve macro: WH_LNG_MergeError1
Template Error: can not resolve macro: WH_LNG_MergeError2
Template Error: can not resolve macro: WH_LNG_JS_alert_ProjectLoadingFail
..Template Error: can not resolve macro: WH_LNG_PreTooltip in D:\CUACV9\Administ
rator WebHelp\!SSL!\WebHelp\whtopic.js
Template Error: can not resolve macro: WH_LNG_NextTooltip in D:\CUACV9\Administr
Template Error: can not resolve macro: WH_LNG_Show_Navigation_Component in D:\CU
ACV9\Administrator WebHelp\!SSL!\WebHelp\whtopic.js
Template Error: can not resolve macro: WH_LNG_Hide_Navigation_Component in D:\CU
Template Error: can not resolve macro: WH_LNG_SyncTocTooltip in D:\CUACV9\Admini
If I delete my !Language! folder, I get what looks like the same errors within the RoboHelp GUI.
I have tried a couple of the "solutions" that I found online: copying RoboHHRE.lng from the relevant !Language! subfolder to the project folder, and changing the project to a different language and back to the one I want to use. But all to no avail.
Does anyone know of a solution, please.
Many thanks!
3.1K
Macro errors are usually caused be permissions issues. There is a Command Line Generation article by Bill Albing hosted on my site.
@petergrainge
Thanks Peter.
My cmd window is created with administrative privileges.
Yes, I have seen Bill's article (that's how I found out about RHCL!), but he doesn't mention privileges or permissions.
Regards
Ian
This thread seems to have the same errors at the end with no further response.
http://adobe.hosted.jivesoftware.com/message/3757759?tstart=0
I'll ping a couple of people to see if they can help.
Is your output WebHelp or WebHelp Pro?
@petergrainge
Advisor ,
Hi folks. I don't have an answer, but I helped someone last year with something similar. I'm not sure if it was related to using the RHCL, an LNG file problem, or in anyway related to RoboHelp Server. But I'll ping the person at Adobe that I had worked with previously and see if we can resolve this.
Ian, have you reported this to Adobe Technical Support? If so, it would help if you could send me any case numbers or contacts to my email (see my profile). Also, as Peter mentions, we need to know to what kind of server the RHCL is trying to communicate with. Were you ever able to publish from the RH client to your web server in the conventional way? This would help validate that the permissions from your machine are valid. I'm a networking novice, but it does have the look of a permission thing.
John Daigle
Adobe Certified RoboHelp and Captivate Instructor
Evergreen, Colorado
www.showmethedemo.com
John Daigle
Newport, Oregon
HI John,
Thanks for your mail.
No, I have not reported this to Adobe Technical Support.
I am producing WebHelp with both source and output on my laptop. There is no separate web server involved in the process.
Everything works fine (and has always worked fine) from the RH GUI, although it appears (I haven't looked in detail) that I can replicate the problem there by deleting !Language!
In the past I have manually generated the help and then copied the relevant folders to another machine.
I have just started investigating RHCL because my development team would like to be able to automate Help creation so that it is part of the s/w build process.
Regards
Ian
Sep 25, 2012 Sep 25, 2012
Hi John,
Have you heard anything from your Adobe contact?
As mentioned, all my RH publishing work is done within my laptop, with manual copying of files to remote servers after they have been generated.
Thanks for your help!
Regards
Ian
Advisor ,
HI, Ian
Sorry to be AWOL. I've been on the road for quite some time and I'm behind on this. Let me ask again and I'll get back.
john
John Daigle
Newport, Oregon
Hi Peter,
I am trying to produce WebHelp.
Everything works fine from the RH GUI, but not from CMD.
Regards
Ian
Sep 24, 2012 Sep 24, 2012
Hi Peter,
I just wondered if you’d had any luck with your pingings?
Regards
Ian
John did respond to you.
@petergrainge
Ah! He was your ping.
John's response did not contain a solution, and I did respond back to him.
I will chase him to see if he has heard anything from his Adobe contact.
Engaged ,
HI
  even in older version of RoboHelp we do get such an error if we do not generate WebHelp output from RoboHelp UI even once and directly try to generate from RHCL.
for any new project at least generate WebHelp once and try RHCL after that, please update if you still get such errors.
Hope this will help
Ashish
Hi Ashish,
The project I am trying to compile with RHCL is one I have compiled many times (and still can compile) using the GUI. It is not a new project.
What do you mean by "update"? I am using 9.0.2.271.
Thanks and regards.
Ian
Sep 26, 2012 Sep 26, 2012
RH9 is no longer the current version with the release of RH10 - maybe that's the "update" RoboAsh is talking about?
Maybe Jeff...
However, as my RH9 is part of TCS3, I don't think I'll be able to persuade my company to cough up over £700 for an upgrade on the off-chance that something that should work in my current version actually will do in the latest.
Regards
Ian
If you've got a spare machine kicking around, it might be worth it to pull down the trial version & play with it using a copy of your project to see how it performs.
Regarding the upgrade cost - our organization bought a 2 year upgrade plan (which includes bronze support thrown in too) for less than that I think.
Engaged ,
Sep 27, 2012 Sep 27, 2012
HI Ian,
      Can you please confirm if you or anyone else has done any changes to the files kept in "whxdata" folder in your RoboHelp install folder or by any change you have updated the lng xml file of your project?
by the way by update I just meant the RoboHelp 9 updates and not upgrading to RoboHelp10.
but I would be tempted to talk about the new features like multiscreen output - it can produces highly customizable outputs which can be viewed on any modern device like tablets or smart phones.
Regards
Ashish
Sep 28, 2012 Sep 28, 2012
Hi Ashish,
No, no one has touched the files in the whxdata folder (I didn't even know of it's existence until I searched for it following your mail).
As for the  RoboHHRE.lng file, I have tried the solutions from http://forums.adobe.com/message/2279210, which involved placing a copy of the file in the project folder and adding the following line to the file:
<element name="FtsMaxResult" value="Search results per page" />
The current situation is that both files exist and both include that line.
I have not been able to compile from RHCL in any configuration.
Regards
Ian
Oct 16, 2012 Oct 16, 2012
Hi!
Good news! A colleague of mine has solved this problem!
The key is to use the full path name of the RHCL command.
I was using
rhcl "D:\XYZ\Administrator WebHelp\WebAdmin.xpj" -l WebHelp
but this generated the errors I reported.
However, the following works perfectly:
"C:\Program Files (x86)\Adobe\Adobe RoboHelp 9\RoboHTML\rhcl" "D:\XYZ\Administrator WebHelp\WebAdmin.xpj" -l WebHelp
The quotes are needed because of the spaces in the path to RHCL.
Jan 24, 2017 Jan 24, 2017
We get a similar error with template when compiling with RHCL. We use RoboHelp 11.
Initial issue:
Preparing to create WebHelp...
Preparing files for WebHelp...
Copying files...
Warning: "D:\TallyHelp\rel-5-5\te9_5-5\" cannot be copied to" D:\Output\RoboHHRE.lng". reason: source does not exist.
Updating files...
Towards the end it shows template errors as given in your post.
However, these did not seem to show any issue with the compiled WebHelp.
Noticed this with a project created in an older version of RoboHelp and migrated to RoboHelp 11. The same template issues are shown when compiling from the UI too.
RoboHelp Documentation
Download Adobe RoboHelp
