15 Replies Latest reply: Oct 11, 2012 1:50 AM by Gang_Z RSS
    Rename, New folder action using Drive CMIS connector
    mandarpkulkarni@gmail.com Community Member
      I am trying to work on "Rename" and "New Folder" actions from Drive. To give more details - when I connect to our DAM using Drive, the DAM gets mounted as a network drive and can be accessed from Windows Explorer. I was told on one of the Adobe forums thread that Drive uses the Windows in-built context menus to initiate these actions.
      Refer: http://forums.adobe.com/message/3807568#3807568
      But when I try "New Folder" menu, Explorer gives me "Access denied" or "You need permission" kind of error. On "Rename" I get similar error. I believe both these errors are due to the fact that I am trying to modify certain things on a network drive. But then what would be the work around so that I can perform these actions on a CMIS server using Drive?
      We are adding CMIS layer on top of our DAM so that it will work as a CMIS server. For connection with Drive, we use the default CMIS connector that comes with it.
        • 1. Re: Rename, New folder action using Drive CMIS connector
          Gang_Z Community Member
          Please don't add/move files and folder under the root folder of the mounted drive, currently, there is a design limitation here, thanks
          Gang
          • 2. Re: Rename, New folder action using Drive CMIS connector
            Yes, I am aware of that limitation. But I have seen this behavior even inside other folders on the mounted drive.
            • 3. Re: Rename, New folder action using Drive CMIS connector
              Please post the log here, then we can do a quick check
              • 4. Re: Rename, New folder action using Drive CMIS connector
                Logs on "Rename" action
                2012/09/28 05:34:58,691 [IFSConnection-1] FATAL IFSConnection - NASTY Runtime exception for Request: RENAME
                com.adobe.drive.biz.filesystem.FileSystemException: java.lang.NullPointerException
                    at com.adobe.drive.internal.biz.filesystem.FileSystemService.run(FileSystemService.java:1680 )
                    at com.adobe.drive.internal.biz.filesystem.FileSystemService.run(FileSystemService.java:1646 )
                    at com.adobe.drive.internal.biz.filesystem.FileSystemService.rename(FileSystemService.java:9 81)
                    at com.adobe.drive.ifs.job.RenameHandler$1.call(RenameHandler.java:95)
                    at com.adobe.drive.ifs.job.RenameHandler$1.call(RenameHandler.java:1)
                    at com.adobe.drive.model.context.Context.run(Context.java:88)
                    at com.adobe.drive.ifs.internal.IFSConnection.dispatch(IFSConnection.java:187)
                    at com.adobe.drive.ifs.internal.IFSConnection.run(IFSConnection.java:142)
                Caused by: java.lang.NullPointerException
                    at com.adobe.drive.connector.cmis.client.CMISProxy.buildQuery(CMISProxy.java:2086)
                    at com.adobe.drive.connector.cmis.client.CMISProxy.query(CMISProxy.java:1987)
                    at com.adobe.drive.connector.cmis.client.CMISProxy.getDescendantDocuments(CMISProxy.java:196 1)
                    at com.adobe.drive.connector.cmis.client.CMISProxy.hasCheckedOutDocumentsByAnyUser(CMISProxy .java:1920)
                    at com.adobe.drive.connector.cmis.handler.Handler.isCheckedOut(Handler.java:305)
                    at com.adobe.drive.connector.cmis.handler.MoveHandler.execute(MoveHandler.java:95)
                    at com.adobe.drive.connector.cmis.handler.MoveHandler.execute(MoveHandler.java:1)
                    at com.adobe.drive.internal.data.manager.DataManager.execute(DataManager.java:3162)
                    at com.adobe.drive.internal.data.manager.DataManager.execute(DataManager.java:3114)
                    at com.adobe.drive.data.manager.call.AbstractFSCall.executeConnector(AbstractFSCall.java:323 )
                    at com.adobe.drive.data.manager.call.Move.callConnector(Move.java:501)
                    at com.adobe.drive.data.manager.call.Move.moveRemoteSource(Move.java:302)
                    at com.adobe.drive.data.manager.call.MoveFinder.moveToEmptyDestination(MoveFinder.java:83)
                    at com.adobe.drive.data.manager.call.MoveExplorer.moveToEmptyDestination(MoveExplorer.java:7 0)
                    at com.adobe.drive.data.manager.call.Move.execute(Move.java:142)
                    at com.adobe.drive.internal.data.manager.DataManager.moveAsset(DataManager.java:3892)
                    at com.adobe.drive.internal.biz.filesystem.FileSystemService$12.execute(FileSystemService.ja va:998)
                    at com.adobe.drive.internal.biz.filesystem.FileSystemService$FSRunnable.run(FileSystemServic e.java:1803)
                    at com.adobe.drive.data.internal.persistence.PersistenceRunner.run(PersistenceRunner.java:11 9)
                    at com.adobe.drive.internal.biz.filesystem.FileSystemService.run(FileSystemService.java:1666 )
                    ... 7 more
                Logs on "New folder" action
                2012/09/28 05:23:42,321 [IFSConnection-1] FATAL IFSConnection - NASTY Runtime exception for Request: CREATE
                com.adobe.drive.biz.filesystem.FileSystemException: com.adobe.drive.data.model.DriveException: Error creating directory
                    at com.adobe.drive.internal.biz.filesystem.FileSystemService.wrapException(FileSystemService .java:1623)
                    at com.adobe.drive.internal.biz.filesystem.FileSystemService.run(FileSystemService.java:1673 )
                    at com.adobe.drive.internal.biz.filesystem.FileSystemService.create(FileSystemService.java:8 67)
                    at com.adobe.drive.ifs.job.CreateHandler$1.mkDir(CreateHandler.java:204)
                    at com.adobe.drive.ifs.job.CreateHandler$1.call(CreateHandler.java:183)
                    at com.adobe.drive.ifs.job.CreateHandler$1.call(CreateHandler.java:1)
                Caused by: com.adobe.drive.data.model.DriveException: Error creating directory
                    at com.adobe.drive.internal.data.manager.DataManager.create(DataManager.java:4434)
                    at com.adobe.drive.internal.biz.filesystem.FileSystemService$10.execute(FileSystemService.ja va:885)
                    at com.adobe.drive.internal.biz.filesystem.FileSystemService$10.execute(FileSystemService.ja va:1)
                    at com.adobe.drive.internal.biz.filesystem.FileSystemService$FSCallable.run(FileSystemServic e.java:1767)
                    ... 7 more
                There might be something wrong with our implementation as well. But I am not able to figure out where lies the problem.
                • 5. Re: Rename, New folder action using Drive CMIS connector
                  just from the log, it seems our CMIS connector cannot get correct capabilities related to move, create operation from your DAM, please check it you DAM exports those capabilities according to CMIS 1.0 spec
                  • 6. Re: Rename, New folder action using Drive CMIS connector
                    Okay, that sounds helpful. I will check the set of CMIS methods we have written so far. Our project is work-in-progress. This has been the main obstacle where we don't know what action from Drive side will invoke which methods on our side.
                    • 7. Re: Rename, New folder action using Drive CMIS connector
                      I believe CMIS connector reads the capabilities returned by getRepositoryInfo method, correct? I checked our implementation and the method returns the capabilities consistent with our system's properties. Do you have more information on which specific capability and its value is expected by Drive's CMIS connector?
                      • 8. Re: Rename, New folder action using Drive CMIS connector
                        Yes, our CMIS connector reads the capabilities returned by getRespositoryInfo method
                        few questions here
                        1) Does your Implementation of CMIS are compliant with RFC4287 and RFC5023?
                        2) Are the capabilities elements returned with cmis prefix and referred by the namspace http://docs.oasis-open.org/ns/cmis/core/200908/?
                        3) Is it possible you were testing as an user with limited modifiable rights?
                        • 9. Re: Rename, New folder action using Drive CMIS connector
                          To answer your questions:
                          #1. I believe these are Atom Syndication Format and Atom Publishing Protocol RFCs. Our CMIS implementation is still a work in progress. So some CMIS methods are complete, some are underway. For the methods completed we have tried to be consistent with the sample output shown in CMIS spec. But I am revisting our code to check the compliance with the RFCs you mentioned.
                          #2. I am checking this.
                          #3. Which user are you refering to - user of our DAM system which is entered in Drive's (CMIS connector) login window or the Windows user?
                          • 10. Re: Rename, New folder action using Drive CMIS connector
                            #1. I have verified compliance with the specified RFCs.
                            #2. Yes, the capabilities elements are returned with cmis prefix and referred by the required namespace.
                            #3. I assume you were talking about the user of our system that I use for CMIS connector login. In that case, yes, I have been testing this admin user.
                            Any other thoughts why I might be facing the problems still?
                            • 11. Re: Rename, New folder action using Drive CMIS connector
                              Hi
                              Currenly, no any idea further. however I'd like to help you on this if you can provide more information, like your connector jar, how to connect to a instance of your server. maybe I can debug it for you
                              • 12. Re: Rename, New folder action using Drive CMIS connector
                                That sounds great. Much appreciated. Would you like to take the discussion forward here or over email?
                                Ours is a .NET application. I can provide you the url of CMIS server endpoint and the credentials. What else would you need?
                                • 13. Re: Rename, New folder action using Drive CMIS connector
                                  let discuss it over email.
                                  Please send me the url of CMIS server endpoint, the credentials and the connector jar, thanks.
                                  I cannot give you an ETA of the invetigation result, I hope I can finish it in two-three days
                                  • 14. Re: Rename, New folder action using Drive CMIS connector
                                    Please let me know the email id on which I am supposed to send the details.
