After the deploy of 11.4.402.278 version with .MSI file, the Controll panel, falsh 32, tab advanced shows the 11.4.402.278 version.
in control panel, install e remove application, the Flash version is always the preview 11.4.402.267 version.
So i can't obtain a correct report with SpiceWorks(a scan network software)because the installed version remain the 11.4.402.267.
If i install Flash 11.4.402.278 manually with the .exe files, in the installed application i find two versions installed and i must remove manually the 11.4.402.267 version.
Before the 11.4.402.278.msi release everything worked well.
For the deploy i use the Kaspersky Security Center Consolle.
Any ideas?
If you look at the Properties of the MSI installers, what is the digital signature date? It should be September 17.
If it is not, maybe you have downloaded a cached version of an older MSI installer.
yes, it is September 17.
it seems to be an error in the installer written version because the Flash control panel shows the right version.
This is a known bug in our MSI installer (our internal bug number is 3333545). It should be addressed in our next update.
Chris
