Presenter is producing the following error in all circumstances:
Adobe Presenter has encountered an unexpected problem while working with this presentation...
Powerpoint 2010 starts normally, but the error appears every time I attempt to access any features or menu choices in the Presenter submenu. It occurs in new presentations as well as when I attempt to access or edit existing ones. My office would have to re-install the software if that is my only option, but I don't have admin rights to this unit. Is there anything I can do? I saw some crash workarounds that simply involved deleting files, but I don't know what to do here. I will continue to scour the forum looking for solutions. Help!
Hello,
Welcome to Adobe Forums.
Which version of Adobe Presenter are you using ?
Do you have McAfee as your Anti Virus Protection ?
Vikram
Hello, there
I'm also have this problem. I use adobe presenter V.7 and McAFee. Could you please solve this problem. Thanks
Hi
Plese refer to this blog for details
Can you please try re-installing presenter?
It should directly fix the issue.
You can find all the installers here
http://www.adobe.com/cfusion/tdrc/index.cfm?loc=en_us&product=presenter
Mahesh
I am also using Presenter 7.x and McAfee OAS. I apologize for being obtuse, but which blog? Was there supposed to be a link attached to that comment?
Hello,
Please share your Contact Information on tcssup@adobe.com and I will send you the troubleshooting steps to fix this issue.
Vikram
Missed the link
http://blogs.adobe.com/captivate/2012/09/mcafee-virus-alert-on-adobe-presenter-8.html
thanks
Mahesh
I receive the same error. I went back to my installed programs and repaired the Adobe presenter and the problem went away.
Same issue. Not running McAfee, but rather Sophos. Any help would be greatly appreciated.
I had the same error. I disabled all other add-ins within Power Point and left the Adobe Presenter add-in as the only active one. The errors stopped after that.
