Locked
installing of Flash Player on Windows 7 !!!
Guest
Oct 01, 2012 Oct 01, 2012
hello, this is the system final comment of above installation,
to be submitted to Adobe:
quote
PLATFORM VERSION INFO
Windows: 6.1.7601.65536 (Win32NT)
Common Language Runtime: 4.0.30319.269
System.Deployment.dll: 4.0.30319.1 (RTMRel.030319-0100)
clr.dll: 4.0.30319.269 (RTMGDR.030319-2600)
dfdll.dll: 4.0.30319.1 (RTMRel.030319-0100)
dfshim.dll: 4.0.31106.0 (Main.031106-0000)
ORIGINS
Distribution URL: file 😕 / / C 😕 Users/ANTON/AppData/Local/Temp/install_flashplayer11x32ax_gtba_chra_dy_aih.bat
ERROR SUMMARY
The following is a summary of the errors. Detailed information about these errors are listed later in the log.
* Activation of C: \ Users \ ANTON \ AppData \ Local \ Temp \ install_flashplayer11x32ax_gtba_chra_dy_aih.bat caused an exception. Were detected the following error messages:
+ Exception reading manifest from file 😕 / / C 😕 Users/ANTON/AppData/Local/Temp/install_flashplayer11x32ax_gtba_chra_dy_aih.bat: manifest is not valid or can not open the file.
+ Detected invalid data at the root level. Line 1, position 1.
COMPONENT STORE TRANSACTION FAILURE SUMMARY
No transaction error was detected.
NOTICES
No warnings during this operation.
OPERATION PROGRESS STATUS
* [01/10/2012 23:52:47]: Activation of C: \ Users \ ANTON \ AppData \ Local \ Temp \ install_flashplayer11x32ax_gtba_chra_dy_aih.bat started.
ERROR DETAILS
During the operation, the following errors were detected.
* [01/10/2012 23:52:51] System.Deployment.Application.InvalidDeploymentException (ManifestParse)
- Exception reading manifest from file 😕 / / C 😕 Users/ANTON/AppData/Local/Temp/install_flashplayer11x32ax_gtba_chra_dy_aih.bat: manifest is not valid or can not open the file.
- Origin: System.Deployment
- Stack Trace:
in System.Deployment.Application.ManifestReader.FromDocument (String localPath, ManifestType manifestType, Uri SourceUri)
in subStore, Uri & SourceUri, & tempfile tempfile, & SubscriptionState substate, IDownloadNotification notification, DownloadOptions options, ServerInformation & serverInformation)
in System.Deployment.Application.DownloadManager.DownloadDeploymentManifestBypass (SubscriptionStore subStore, Uri & SourceUri, & tempfile tempfile, & SubscriptionState substate, IDownloadNotification notification, DownloadOptions options)
in System.Deployment.Application.ApplicationActivator.PerformDeploymentActivation (activationUri Uri, Boolean IsShortcut, textualSubId String, String deploymentProviderUrlFromExtension, BrowserSettings browserSettings, String & errorPageUrl)
in System.Deployment.Application.ApplicationActivator.ActivateDeploymentWorker (Object state)
--- Inner Exception ---
System.Xml.XmlException
- Invalid data was detected at the root level. Line 1, position 1.
- Source: System.Xml
- Stack Trace:
in System.Xml.XmlTextReaderImpl.Throw (String res, String arg)
in System.Xml.XmlTextReaderImpl.ParseRootLevelWhitespace ()
in System.Xml.XmlTextReaderImpl.ParseDocumentContent ()
in System.Deployment.Application.ManifestValidatingReader.XmlFilteredReader.Read ()
in System.Xml.XmlCharCheckingReader.Read ()
in System.Xml.XsdValidatingReader.Read ()
COMPONENT STORE TRANSACTION DETAILS
No transaction information is available
unquote
please kindly comment and give related fix instructions, thanks and regards,
Antonella
863
Adobe Employee ,
Moving this discussion to the Installing Flash Player forum.
