1. Re: Rotate element by dynamic amount
TimJaramillo Oct 3, 2012 11:10 AM (in response to richtelford)Hi richtelford, yes- you can dynamically rotate an object using css, like this:
var your_angle = 50;
sym.$("your_wheel").css('transform','rotate(' + your_angle + 'deg)');
sym.$("your_wheel").css('-moz-transform','rotate(' + your_angle + 'deg)');
sym.$("your_wheel").css('-webkit-transform','rotate(' + your_angle + 'deg)');
sym.$("your_wheel").css('-o-transform','rotate(' + your_angle + 'deg)');
2. Re: Rotate element by dynamic amount
resdesign Oct 3, 2012 11:13 AM (in response to TimJaramillo)Brilliant Tim!
3. Re: Rotate element by dynamic amount
richtelford Oct 3, 2012 3:49 PM (in response to TimJaramillo)So I would put this as a trigger action on the frame I want it to start? How would I specify the duration of the rotation? Say for example I want it to last for 2 seconds.
Richard
4. Re: Rotate element by dynamic amount
TimJaramillo Oct 3, 2012 4:12 PM (in response to richtelford)Hey richtelford, the code I supplied just sets the rotation once.
In order to animate a rotation, 2 options come to mind:
1. use setInterval to repeatedly call a "rotate" function, (containing the code I gave you), increase the "your_angle" var at each function call.
2. use jQuery animate. This is a hacky trick that uses the "step" method in the jQuery "animate" method. "Step" is repeatedly called at each step of the animation. I'm animating an arbitrary property "bottom", which doesn't affect this object. Put the code below in the Stage/compositionReady event. Here's where I got this hack: http://jsfiddle.net/39pe6/
sym.$( "your_symbol" ).animate({"bottom": "200px"},
duration: 5000,
step: function( now, fx ){
sym.$("your_symbol").css ({"-moz-transform":"rotate("+now+"deg)",
"-webkit-transform":"rotate("+now+"deg)",
"-ms-transform":"rotate("+now+"deg)",
"-o-transform":"rotate("+now+"deg)"});
},'linear');
5. Re: Rotate element by dynamic amount
richtelford Oct 4, 2012 1:01 AM (in response to TimJaramillo)Ah I was kinda hoping there would be an Edge solution. I can do all that without using Edge. What would be the advantage of doing this in Edge?
Thanks. I really appreciate the help here guys.
Rich
6. Re: Rotate element by dynamic amount
TimJaramillo Oct 4, 2012 9:38 AM (in response to richtelford)Hey richtelford. Ya, Edge doesn't have a built-in dynamic rotation animation feature. In fact, it doesn't have dynamic animation features at all (Flash doesn't either though ...). Right now, Edge is focused on timeline-based animation. As you know, you can leverage javascript to extend Edge's capabilities.
"What would be the advantage of doing this in Edge", you ask? For me, the biggest advantage of Edge, over doing everything through straight JS, is the WYSIWYG layout capabilities, and the ability to nest symbols to create complex animations and interactions. You can lay out your graphics right there on the stage in Edge, and really see what's going on. I use Edge kinda like how I use Flash- I lay out all my graphics on the stage, but I do most of the funcitonality through code.
Not to detract from Edge, but TweenMax js (GSAP) is extremely cool too. You should be able to import that library, and tween dynamic rotations to your heart's content, while still getting the benefits of the Edge interface.
7. Re: Rotate element by dynamic amount
Jerry Witt Oct 4, 2012 7:06 PM (in response to TimJaramillo)Just spitballin' here, but what if he were to make his gear animate over 360 frames. He could then pass the degree of rotation he wanted to go to finalRotation=r. And then use sym.stop(r);
8. Re: Rotate element by dynamic amount
richtelford Oct 5, 2012 12:46 AM (in response to Jerry Witt)Hi guys,
I already have my gears animating across the full dial so based on what you've both said can I just specify/set the final rotation degree with script/code? E.g. onLoad (or whatever the equivalent is) var angle = XXX; sym.finalRotation = angle;. Sorry I'm not familiar with the methods and syntax of Edge yet. Though it seems Javascript-based.
TweenMax sounds great also. I'm not sure if I have time to implement it in my current project but I will experiment with it for future work.
Thanks again,
Rich
9. Re: Rotate element by dynamic amount
TimJaramillo Oct 5, 2012 9:22 AM (in response to richtelford)@Jerry, yea he could rotate on the timeline, and then use sym.stop(r), though he would still need a setInterval to actually animate to the appropriate angle. At that point, he might as well rotate through code.
@richtelford: in my opinion, you should use the jQuery animate method, and the step hack, which I posted above. It's smooth, and easy. And, yes indeed, Edge runs on javascript, so most anything you can do in javascript you can do in Edge. So when you're looking for how to do stuff in Edge, just do a search on how to do it in javascript.
10. Re: Rotate element by dynamic amount
richtelford Oct 6, 2012 6:31 AM (in response to TimJaramillo)You're right Tim. It's super easy to achieve simply using the jquery animate function. Thanks man.
Rich
11. Re: Rotate element by dynamic amount
TimJaramillo Oct 8, 2012 9:34 AM (in response to richtelford)Right on, no problem Rich! If you want to mark my post with the jQuery animate solution as "correct", it will help other folks who are looking for the solution to the same question.
Cheers!
12. Re: Rotate element by dynamic amount
jay_harlow Mar 27, 2013 7:33 AM (in response to TimJaramillo)Hi Tim,
I'm trying to do something similar and have seen your posts on a number of rotation-related posts and have tried them all. Problem is, I can't get any of the .css('transform','rotate([foo]deg)'); patterns to work.
For example, this will animate the opacity of the symbol, but not the rotation (I'm using Safari):
sym.$('bar1').animate({
opacity:0.25,
'-webkit-transform': 'rotate(45deg)'
}, 500, function() {
Trying to debug it, I simplified your non-animated example above, and not even that will work:
sym.$('bar1').css('-webkit-transform','rotate(45deg)');
I assume there's something really dumb I'm missing but I cannot figure out what it is. Any ideas? Thanks!
13. Re: Rotate element by dynamic amount
TimJaramillo Mar 27, 2013 9:53 AM (in response to jay_harlow)Hi Jay,
The problem is, you cannot directly manipulate the rotation property with the jQuery "animate" method. So in my example, I used the "step" property to call the rotation at every "step" of the tween. I mentioned this here:
In the second static example, you're missing several things. You put a comma where there should be a colon. You also need to put the items in an object, between curly braces, {}. Your second, static example should be this:
sym.$("bar1").css ({"-webkit-transform":"rotate(45deg)"});
HOWEVER, I would highly recommend tossing the jQuery animate method, and instead looking into the GSAP animation library. This library will change your life. You will become a titan among men if you master the GSAP library, along with Edge Animate.
Below is an example of rotating a div and changing it's alpha using GSAP. It's so simple- the library takes care of all the different browser prefixes, etc.
Example:
www.timjaramillo.com/code/edge/gsap_rotate
Source:
www.timjaramillo.com/code/edge/_source/gsap_rotate.zip
GSAP info:
http://www.greensock.com/get-started-js/
Code on Stage.CompositionReady:
// use yepnope to load the greensock libs
yepnope(
nope:[
'greensock/TweenMax.min.js',
'greensock/easing/EasePack.min.js',
'greensock/plugins/CSSPlugin.min.js',
'greensock/plugins/ColorPropsPlugin.min.js'
complete: init
//when yepnope has loaded everything execute init();
function init (){
// assuming you have a symbol named "Rectangle" at Stage root
var RectangleSymbol = sym.$("Rectangle");
TweenMax.to(RectangleSymbol, 1, {rotation:45, opacity:0.7, ease:Bounce.easeOut});
14. Re: Rotate element by dynamic amount
richtelford Mar 27, 2013 10:25 AM (in response to TimJaramillo)Just wanted to follow up on this.. here is what I ended up with:
I have been looking into using Greensock stuff for a separate project. It looks amazing.
15. Re: Rotate element by dynamic amount
jay_harlow Mar 27, 2013 10:29 AM (in response to TimJaramillo)Thanks, Tim. I think I picked up that comma syntax from a JQuery example, though that one uses step too. Still can't get that static code to work even as you wrote it, but the step function works great.
I will definitely check out GSAP. Thanks!
16. Re: Rotate element by dynamic amount
TimJaramillo Mar 27, 2013 10:39 AM (in response to jay_harlow)Jay- can you post your file (if you want help with the static rotation)?
Rich- the rotating gears look great!
17. Re: Rotate element by dynamic amount
jay_harlow Mar 27, 2013 10:47 AM (in response to TimJaramillo)Sure, I'd be curious what I'm doing wrong. It's a super basic test file, just one symbol and one line of code:
18. Re: Rotate element by dynamic amount
TimJaramillo Mar 27, 2013 10:50 AM (in response to jay_harlow)Hey jay, in order for me to open the file, I need all dependent js files, not just the .an.
Zip up the whole folder that contains the .an, all the .js files, etc.
19. Re: Rotate element by dynamic amount
jay_harlow Mar 27, 2013 10:51 AM (in response to TimJaramillo)Oops, here you go: https://www.dropbox.com/s/42x4gcb11pr0vhf/test.zip
20. Re: Rotate element by dynamic amount
TimJaramillo Mar 27, 2013 10:56 AM (in response to jay_harlow)Hey Jay, the zip is missing the test.html file. Can you add it and upload again?
21. Re: Rotate element by dynamic amount
jay_harlow Mar 27, 2013 10:57 AM (in response to TimJaramillo)updated
22. Re: Rotate element by dynamic amount
TimJaramillo Mar 27, 2013 11:06 AM (in response to TimJaramillo)Hey Jay, it looks like the CSS rotation prop doesn't work directly on an Edge symbol- you need to target a simple div shape. In your case you would need to do this:
sym.getSymbol("bar1").$('Rectangle').css ({"-webkit-transform":"rotate(45deg)"});
Yet another reason to use GSAP!
23. Re: Rotate element by dynamic amount
jay_harlow Mar 27, 2013 11:49 AM (in response to TimJaramillo)At least I wasn't completely crazy. Thanks Tim!
