Je crains n'avoir créé un niveau supplémentaire problématique, est-ce exact?
...\Formation SIGRH\RBH\SIGRH\!SSL!\FlashHelp\!SSL!\FlashHelp\SIGRH_2012-10-03.html
I guest I created an extra level wich is not correct, am I right?
Merci
Thank you!
Oui!
You should only have 1 \!SSL!\ folder with each type of SSL help in it. When you generate your FlashHelp again, it should have removed the original folder & populated it with the new help contents.
Thank you very, very much for you help! Now, when I want to work on a existant project, do I have to choose the .xpj file IN the !SSL! or not? I know for sure that this is basic knowledge of RoboHelp but I just got my introduction class 2 weeks ago and I am working with another version and I am kind of mixed up...
Looking forward that you can help me again on that one to!
Oh, that's not good - your project (the .xpj) should be a place like c:\projects\project_name\, not inside another project's \!SSL!\ folder. The shorter the paths in a RH project, the better.
Once again, I would like to thank you for your help!
.xpj has to be in project folder where you have the other filesm,please dont change the location of .xpj ,if you move it,you have to move the complete folder named same as the name of your project.
