I have started a project, imported a few dozen files and successfully published it. However, after importing about 400 html files, the program (and project) locks up. Difficult to do simple tasks like opening the table of contents. The application either locks up or takes about 30 minutes to return access to the menu.
Hi there
Does this happen immediately after the import? Or does it continue after closing and restarting RoboHelp?
If you click File > Rename project and note the location of the project, where exactly is this location? If it's on a network drive, that likely explains the slowness. You should keep the project on your local C drive. Preferably in a folder named "Projects".
C:\Projects
C:\Projects\Project1
C:\Projects\Project2
C:\Projects\Project3... Etc...
Cheers... Rick
Hello and thank you for your reply.
The project is on my local hard drive, in a subfolder about 3-4 levels down.
I was able to import about 20 or 30 test files and it worked fine.Then when I tried to import more, that's when the system was "Not Responding". I would have to kill the task then re-open RH. Even then, it was slow. I couldn't even select the File menu without having to wait 5 minutes or more for the menu to appear.
I recently worked on a larger project, importing HTML files to a project that was in a subfolder 3-4 levels down. But that was using RH8 not RH9.
Is the problem only with the project you are importing the 400 topics into? If so, can you give us an idea of what is inside those 400 topics. For example are there loads of images, hyperlinks to other topics / bookmarks, inter-project links and the like.
It so happens that I tested importing the files to another project I worked on a while back. When I did, it crashed the application. So, I think there's something about the files themselves. To answer your questions, the files contain images (I'm not sure how many), lots of bookmarks and lots of links between various documents.
Thank you for any help you can offer!
Hi there
Odds are RoboHelp isn't liking something inside one or more of the files. The trick is to pinpoint exactly WHICH of the files is causing the issue.
I think if I were in your shoes, I'd do the following.
Create a folder and copy all the files to the folder.
Inside that folder, create another folder.
*MOVE* ten files to the sub folder.
From RoboHelp, import the ten files. All okay?
If yes, delete the ten files and try with another group of ten.
Rinse and Repeat as necessary until you find the culprit(s).
The thought is that working with ten files at a go will make it easier to finally identify which of the files may be causing the issue.
Cheers... Rick
I have a project like that a while back albeit on RHX5. It was like a sloth on mogodon! What really killed it was the number of bookmarks (in the 000s). Start off by doing as Rick suggests and see if it is something specific. If it isn't, you may have to live with it or consider splitting it and merging it. But let's go there yet.
Will do! and I agree.....don't want to start splitting up the project yet! I'll let you know my findings.
Wanda
Hello again
Are you using folders in your project? If not, you might want to consider it. By introducing folders, you place fewer files in any given folder. This means RoboHelp doesn't have to work as hard when you perform certain actions. If you have hundreds of files inside a single folder, it can slow things more than you would think as RoboHelp has to keep track of everything going on.
Cheers... Rick
Helpful and Handy Links Captivate Wish Form/Bug Reporting Form |
As a plan b until I get this fixed, I tested importing Word files for the content. The Word file hyperlinks didn't come over!
I'm not seeing in this thread that you have tried deleting the CPD file and then reopening the project.
THANKS! I tried it this morning. That seems to help. RH is now more responsive as I continue to import files.
Thanks again. I'll follow up if the problem resumes.
Go to Tools > Options and tick the option to always delete the cache. That deletes the CPD every time you open RoboHelp. While you are importing files, that file grows quickly and then you have the problem you have seen.
Makes sense. I did something along those lines yesterday and realized it was locking up over a couple of files that were 1,200 to 2,400 kb. So I uploaded everything else (except for those two large files) in groups of 10s and 20s. It progressively starting slowing down again as I got near the end of the files.
I'll keep you posted!
Wanda
