Hello dcfergs -
Ummmm, in this case there is no ".dtd" file (dtd=data type
description). The "eHelp.dtd" in the eHelp.xml file is description
of a file which in your case does not exist. The eHelp.xml file is
generated in RH by default. It is essentially a "boiler plate" with
the default dtd file called "ehelpopt.dtd" which you COULD create
if you wanted some custom stuff. Before you delete the eHelp.xml
file, open it in a text editor and see if it could mess up your
generated Help.
When building the WAR file, ignore that message. You can also
try leaving off the "-i" switch when generating the WAR file (if it
is on) and see if that helps.
gewb
