In another thread I'm asking for help regarding the mapped IDs not being seen when the merged help project is being openend from the application.
Now I'm wondering what might be wrong with my setup.
Where do the subprojects have to put their resulting .chm files? In their respective project directory?
Christoph
There is some information about merged CHMs at the end of my tutorial about merged webhelp. See my site.
Thanks. I visited your site and tried out the rh9_merge sample project.
May I discussit here further or do you suggest another place or means?
I compiled the child projects and then built the parent project afterwards. During building the parent project I'm getting:
Processing keywords...
Generating full-text search data...
HHC6000: Error:
An internal file could not be created. Make certain there is enough disk space on the drive where you are compiling your file.
HHC5007: Error:
Fatal navigational compilation error. This is likely the result of an invalid contents (.hhc) file.
Compacting file system...
The following files were not compiled:
Kompilierung von HTML-Hilfe in 1 Sek. abgeschlossen.
Kompilierung abgeschlossen
Christoph
Those errors are not normal encountered with the demo. My guesses are that you have not amended some path and are generating to drive that does not exist, not removed the redirect which is not needed with a CHM merge, or your project is on a network drive.
Hi Peter,
I turned back today to the rh_merge project demo.
I took the rh9_merge.zip file. Unpacked everything into
c:\rh9_merge, went into source\projects\child[123] subsequently, built every child
(the Microsoft HTML Help output->Generate) and they built fine.
Going into source\parent afterwards, clicking on the parent.xpj file and clicking then on Generate in the Microsoft HTML Help output section, yields the reported error:
Kompilierung wird gestartet...
HTML-Hilfe-Vorprozessor 9.0.1.262
C:\rh9_merge\source\parent\!SSL!\Microsoft_HTML_Help\!chm_tmp_folder_0\Parent.chm wird kompiliert...
Erstellung von HTML-Hilfe wird vorbereitet...
Ausgabeordner wird gelöscht...
Dateien für HTML-Hilfe werden vorbereitet...
Dateien werden kopiert...
Dateien werden aktualisiert...
Vorbereitung nach 0 Sekunde(n) abgeschlossen
Compiler wird initialisiert...
HTMLHELP (9.0.1.262) wird generiert...
Themen werden aktualisiert...
parent_redirect.htm wird aktualisiert...
Warnung: Die Größe der Stoppdatei muss auf 512 Byte begrenzt sein.
C:\rh9_merge\source\parent\!SSL!\Microsoft_HTML_Help\!chm_tmp_folder_0\Parent.hhp
Microsoft HTML Help Compiler 4.74.8702
Compiling c:\rh9_merge\source\parent\!SSL!\Microsoft_HTML_Help\Parent.chm
Parent.hhc
Parent.hhk
parent_redirect.htm
Parent.glo
Parent.brs
#BSSC
default.css
RoboHHRE.lng
ehlpdhtm.js
HHC6000: Error:
HHC5007: Error:
I can build the Webhelp Output project without error but the error on the
Microsoft HTML Help project persists.
I checked all permissions on the files to no avail. I'm stuck.
Edit: FWIW, I tried to run the example on a different computer (Windows 7/64, and RH10, of which I installed
a trial version). The same error.
Christoph
The project is set up for merged webhelp and there are things that need to be changed if you are merging CHMs.
In the TOC of the parent, you need to delete the existing links to the children and create links to the child projects again. The links are different. You will need to create the child CHMs before you can do that.
Also the cross project links need to be recreated in a different way.
Thanks for commenting. I hope I can manage it myself to modify the links.
Christoph
See http://www.grainge.org/pages/authoring/merging_webhelp/merging_method_rh9.htm#links
Hi Chris,
As Peter has already suggested however you can try and generate the CHM in C:\New folder location, you won't get this error. I am not sure why it is not able to resolve this long directory.
Hope this helps.
Priyank
I was able to build the WebHelp Demo but the HTMLHelp failed with the above error.
The generated chm file is in:
C:\Users\kuku\Documents\Eigene RoboHelp-Projekte\rh9_merge\source\parent\!SSL!\Microsoft_HTML_Help\parent.chm
but
RH9 created a directory C:\rh9_merge\generate but the child1.chm etc
are in
C:\Users\kuku\Documents\Eigene RoboHelp-Projekte\rh9_merge\source\projects\child_1\!SSL!\Microsoft_HTML_Help\child1.chm.
Invoking parent.chm shows the typical empty info page that the web site cannot be opened.
In every child projects target directory is child1.chm, not child2.chm and child3.chm as one would expect.
Christoph
Chris,
Can you please copy that CHM in your C: drive and then open it. also right click on it and check if you have Unblock button enable, if it is that unblock and then try it.
Priyank
Priyank Srivastava wrote:
Chris,
Priyank
Hi Priyank,
I don't quite understand,what you are saying. What do you mean by
"Copy that CHM in your C: drive" ? I have everything on my C: drive.
Which .CHM do you mean? That one in the weird directory path, Child1.chm?
Right click on it? What do you mean by "Unblock-Button"? Is that within RH9 or in
Windows Explorer?
I found meanwhile that the demo has errors in it, as far as the configuration for
Microsoft HTMLhelp is concerned. The target file is named child1.chm for every child project and not child1,child2,child3 as it should be. That's probably a side problem.
While I was trying to change that name in the options dialog (output folder and filename) I was told by an alert box that the file Microsoft HTML Help.ssl should be writeable.
Well, I looked at it and it was full access for me as owner. I also could change the file name to Child3.chm (Child2.chm). Seems that this is a one time alert which appeared only once as a warning(?). Wonder why it appeared at all when the file was writeable anyway.
So far so good, I'm trying to get that demo project working with merged CHM files.
