Locked
4
Enhance Thin Lines Off!
Jun 23, 2010 Jun 23, 2010
Adobe needs to make the enhance thin lines option a document specific property; like initial view magnification or layout.
Too often does this view preference cause elegant subtle lines to be viewed as bulky eye sores. As a designer when I set a line weight at .25 pt or .125 pt, That's the line weight I want it to be viewed at! on screen or on print. It does not make sense to need to ask clients to change their adobe acrobat preferences to uncheck enhance thin lines off, so that they can view a document properly.
.PDF documents need to have the ability to be initially viewed with the enhance thin lines option unchecked.
Who's with me? How do we get adobe to make this important change?
56.0K
Adobe Employee , Sep 30, 2012 Sep 30, 2012
>I recognise that as programs evolve they optimise for different types of users.
>My preference would be "Not to have" the Enhance thin lines option.
Exactly.  For you, you'd like it not to do that.  For other users, they want it to happen.   That's why it's a preference
FWIW: That setting was created to work around a problem in some 3rd party PDF creation applications for office-class applications where the lines of a spreadsheet or table would disappear when viewed in Acrobat becuse they were "
Sep 23, 2010 Sep 23, 2010
I couldn't agree more!  I also have the problem that the reader and acrobat are adding white lines at the edges of my documents (typically lower and right sides).  It also seems to be cropping the stroke/frame that I sometimes use at the outer edge of an image.  This might not be too bad, except it doesn't crop the edges evenly, so any frame you have placed in Illustrator comes out looking uneven and (as with the white lines) very amateurish.
Aug 24, 2011 Aug 24, 2011
I am 100% with you that the preference enhance thin lines should be document specific.
Oct 09, 2011 Oct 09, 2011
This is a topic I've been hoping that would get addressed. As a designer it is important to have 100% transparency between how I view my work and how I want my clients or viewers to view my work. I find it frustrating to not have this and more importantly I feel that it is awkward to direct my clients or even institutions on how THEY SHOULD view or do something by telling them directions on turning off this option. I just find it offensive and a turnoff to them. I already sent in a request to Adobe to expand the specific/customizable intitial view settings for specific pdfs. I was wondering if there were any updates on this issue or any tweaks/fixes/known scripts or anything?!
Nov 15, 2011 Nov 15, 2011
I can't believe there's a default preference that makes certain fonts look horrendous on screen. I wonder how many hiring managers have looked at resumes and assumed the applicant was a sloppy typist. How has Adobe missed fixing this over multiple versions?
Advocate ,
Nov 19, 2011 Nov 19, 2011
It might be an idea to have this setting document-specific.
However, this setting only makes sense if your display unit has a resolution of 600 dpi or more (if looking at your document at 100%).
It is simple math. Take your monitor's resolution and calculate the narrowest line it can display, considering that 1 pt is 1/72 of an inch.
Next simple math example: calculate which resolution your monitor needs to display a line 1/8 of a point wide.
Hope this helps.
Max Wyss.
Aug 15, 2012 Aug 15, 2012
This needs to be solved!
A major point of adobe is to know how the recipient sees your content.
Just stupid that non serif letter Capital i and and non capital L - becomes bolder if enhance thin lines is active.
Manolo
Adobe Employee ,
Sep 03, 2012 Sep 03, 2012
Hi All,
You can put your bug report or feature request for any Adobe Product at :
https://www.adobe.com/cfusion/mmform/index.cfm?name=wishform
Thanks.
Adobe Employee ,
[admin - insulting comments removed ]
The "enhance thin lines" setting ONLY WORKS on vector lines.  So if you were to leave your text as text - which is what you should be doing anyway - then you would NEVER see this.
My point was that generally I would like to have my content appears as I intent. The PDF/Adobe reader combi has been very good at this.
As to the point of vector vs. text - I generally don't convert text to vector but in illustrators PDF export it's a problem.
Please note that there are many threads about this problem.
M
Adobe Employee ,
FWIW: That setting was created to work around a problem in some 3rd party PDF creation applications for office-class applications where the lines of a spreadsheet or table would disappear when viewed in Acrobat becuse they were "too thin".  Given that were more of those out there than 'outlined text'-based PDFs, we set the defaults to match the more common case.
As to issues with Illustrator' PDF export - I am not aware of any problems with text export in that application.  If you know of a thread or a specific bug number, I am happy to investigate.
Oct 08, 2012 Oct 08, 2012
Enhance thin lines could be programmed to work for lines over "X" lenght - Say 10 mm that way most font i and l would not be affected -
Might be a solution that could benefit both user types.
M
Adobe Employee ,
Thin lines does NOT affect text. It ONLY affects vectors. So as long as you keep your text as text – no problems.
Nov 19, 2012 Nov 19, 2012
lrosenth,
You seem very adamant about your position, and I applaud your passion, however...
We are an architectural firm and generate primarily vector PDFs with text as text. For years now staff has been confused when opening PDF's and the percieved lineweight on screen does not match those chosen in the authoring software. Some staff members (since it is their responsibility to design and not know all of the preference options) have gone as far as to re-generate new PDFs with different settings to try and get the lineweights to display correctly.
We have since changed the preference to OFF in our staff installation. What is most unfortunate about this setting (other than the fact that the deault is inaccurately displaying information) is that up until we changed the setting staff was unable to use Acrobat as a presentation tool. Vector drawings presented via Acrobat were unable to read and destroyed appearance of the artwork. I belive this default "blunder" has placed Acrobat years behind of where it should be for on screen presentation.
Sure, we can turn it off, and we did. Thanks adobe for the heads up(actually not). This reminds me of when the distiller settings were shipped with defaults for internet sharing (2003-ish). I believe we are still recovering from designers who are afraid making a PDF will ruin their artwork... because the are not aware of setting distiller preferences. Education is key, but focusing on the lowest common denominator is a shame.
Adobe Employee ,
RAMSA – I don't think it's "lowest common denominator", but "MOST common denominator".
As mentioned earlier in the thread, this feature (and it's default setting) were added to address a problem with the display of tables and spreadsheets created by Office-class documents. We knew that by making this change we would be impact two other uses – architecture and also prepress (where text is converted to vectors). However, the simple fact is: there clearly exist MANY MANY more Office-class PDFs in the world than those other types.
It's one problem with Acrobat and Reader being used by the EXTREMELY diverse users that it has – we have to make decisions that are good for some set of users and not for others. It is close to impossible to make everyone happy – no matter what we do.
Jul 19, 2013 Jul 19, 2013
I know it's been a while since the last post but I'm running into this problem now. Enhance Thin Lines is ruining how my image is displayed when opened in acrobat. I'm up against a deadline for publishing these and I have at most a day or two to fix this problem.
Is there any way at all to include metadata in the pdf file that displays the content without enhancing thin lines?
Please help. My only other option is to sacrifice the resolution and rasterize these images.
Enhance thin lines has no effect on your artwork. It only changes the way it is displayed on the monitor of the computer you are using.
Your artwork will print perfectly with the feature on or off.
Just tell anyone viewing it in screen to turn the feature off
I'm aware of what this setting does. My problem is that it changes how the image is displayed on the monitor. I have no way of telling people to change their viewing settings. Even if I could, most people who will read my publication online wouldn't have the patience to bother with that anyway. Furthermore, this isn't artwork that I'm trying to publish, rather it's scientific data and accuracy is key. All I need to know is if there is a way that I can control the "Enhance Thin Lines" setting from within the document so that anyone who opens the document will automatically view it WITHOUT thin lines enhanced.
Unfortunately the answer in No, I ended up turning it off in the installation for our 300 users. But you cannot store that setting within the document. Yes, I now understand how rasterizing the PDF would benefit you.
Thanks for your answer. It's a shame that "Enhance Thin Lines" doesn't seem to be among the display settings that one can program into the document. Hopefully adobe will get working on that. Now I'll have to rasterize my vector images, and thus sacrifice resolution, just to ensure that their default settings don't interfere with work. Ugh.
Advocate ,
IMHO, it is a non-problem, and there is no particular way on document level to "solve" it, because the effect will differ from user to user, depending on the screen size (in pixels) and the resolution their Acrobat/Reader is set.
What you can do on document level, would be set it to open at 100%. This may minimize the effect. But, as soon as the users start to change the zoom level, the effect may happen, but always in different ways.
That said, you will have to decide between seeing a line, or seeing no line at certain zoom levels (which may be small when the PDF is viewed on a tablet or a phone).
I found this article which may have a work around:http://www.underconsideration.com/speakup/archives/004301.html
The article is discussing a work around for text that gets distorted, but I think it might be applicable to all thin linework.
I found that in Illustrator if I outline strokes it helps to keep the linework from being distorted, and adding extra points to the stroke, as the article suggests, will help even more.
As I stated in my original post, Adobe should make "Enhance thin lines" a document specific property instead of a preference. We have been requesting this for years.
Adobe Employee ,
As Max points out, making it a document preference would actually cause more harm than good.
The need to "enhance" is entirely based on the users viewing environment – resolution, zoom factor, etc. - combined with the specific attributes of the PDF line(s) in question. So a document has NO WAY to know if that setting will matter – only the viewer does.
As Max said, the right thing to do is prepare your document properly. Use non-fractional widths for your line weights. Set the default view settings for 100% (or something else that works for you).
This is a special case in which the document does know better than the viewer what the "Enhance Thin Lines" setting should be. I'm displaying an image with scientific data - it's content should not change with the viewer's preferences. If it did, it wouldn't be data. I realize that mine is an unusual case but I'm sure there are plenty of others out there.
Adobe Employee ,
Jul 21, 2013 Jul 21, 2013
Can you post a URL to such a file, since I don't really understand if you are looking for something more (such as non-scaling widths) or not?
