Hi, can anyone please assist with this problem? I have inserted Adobe Presenter interactions (accordion menu etc.) into a powerpoint presentation (making sure to save as pptx). When I preview the slides in powerpoint the interactions are live and work, however as soon as I upload them to the Adobe Connect they remain static.
Additionally - is there a way to insert bullet points into the interactions tables where you write content please?
Thank you in advance, Jasmine
Hi Jasmine
When you are uploading the presentation to connect are you uploading the presentation or the published output?
When you are uploading the presentation any external presenter assets will not be published.
In order for the interaction to work, please publish the presentation as a zip on the local system and then upload it to connect
Mahesh
Hello, I would also like to add HTML (Rich text) type content into the Interactions. I cannot seem to do so, the flash won't play properly if I've added a simple hyperlink to the text. What good are interactions if they are only dumb text? How does the user recognize cues to advance to the next slide, or take action as in a decision tree?
