Show 2 replies
1. Re: Editing default navigation tooltips?
RodWard Oct 10, 2012 8:26 AM (in response to crossfireue)No way to do this using Captivate 6.
You'd need to get into the FLA file that was used to create the playbar skin and reprogram the way it works. You need Flash or some other IDE capable of editing FLA files to do that.
2. Re: Editing default navigation tooltips?
crossfireue Oct 10, 2012 8:32 AM (in response to RodWard)Hi Ron – I found the source FLAs just before I saw your response. I've created a duplicate of the skin I want to use, and then in the "Localization" movieclip located inside that FLA's library, I changed all of the tooltip names to what I require.
Thanks for your reply!
