SOLVED
Display data - how to pattern to display to nearest 0.01%?
Avatar
Former Community Member
I'm trying to get a calculated value to display to the nearest 0.01%.  The forumla is simple:  288/12237 = 2.35%.  However, when I set the data pattern to any of the percent options, the only number the calculation returns is 2%.  How can I get the value to return as 2.35%?
1 Accepted Solution
Avatar
Correct answer by
Level 10
use this display pattern:
num{z,zzz,zz9.99 '%'}
Avatar
Correct answer by
Level 10
Avatar
Works for what I intend, although I did have to add a multiplication factor of 100 to the result.  Thanks.
