Every time my application starts it sends it own "Machine ID" to my server to check and see if it has an active license associated with it, If there is a valid license available it returns a temp API Key that the application can use to access my dataservice. If not it prompts the user to register their Machine with a valid license key.
The problem is coming up with a way to Get / Generate a "Machine ID" that every user on the one machine has access to.
I tried using the MAC address and it worked on my PC but on a test user's MacBook it had issues with the order of the NICS changing when calling
private function get_mac():String
var networkInterface : Object = NetworkInfo.networkInfo.findInterfaces();
var networkInfo : Object = networkInterface[0];
return networkInfo.hardwareAddress.toString();
so i could not reliably use this method.( I dont know if something like a wireless switch on a laptop would affect the array of NICS maybe?)
So rethinking everything i decided i would generate my own "Machine ID" using either codegenas3 or mx.utils.UIDUtil;
Then simply storing the "Machine ID" in a common place that every user on the machine would have access to, but I can not figure out where to place it.
So in short where could you store a simple String either in a file or local store that every user would have access to.
I thought this would work but no dice other users on machine were not able to access the wpsc.sys file.
private function get_MachineID():String
var uuid:String;
var _file:File = File.applicationDirectory.resolvePath("wpsc.sys");
var fs:FileStream = new FileStream();
fs.open(_file, FileMode.UPDATE);
if (fs.bytesAvailable == 0)
uuid = UIDUtil.createUID();
fs.writeUTF(uuid);
fs.close();
else
fs.position = 0;
uuid = fs.readUTF();
fs.close();
return uuid;
Well, i was hoping for some help but i did come up with a ROUGH solution that works in my case
private function get_String():String
var uuid:String;
var _file:File = getCommonFile();var fs:FileStream = new FileStream();
try
if(_file.exists)
fs.open(_file, FileMode.READ);
fs.position = 0;
fs.close();
else
fs.open(_file, FileMode.WRITE);
fs.writeUTF(uuid);
fs.close();
catch(err:Error)
Alert.show(err);
return uuid;
* This is what i came up with, one could easily adjust this script to cover their specific Manufacture / OS
private function getCommonFile():File{
var _file:File;
switch(Capabilities.manufacturer)
case "Adobe Windows":
switch(Capabilities.os)
case "Windows 7":
/* Works */
_file = new File("C:\\ProgramData\\MyApp\\File.txt");
break;
case "Windows Vista":
/* Not Tested */
break;
case "Windows XP":
/* Works but required Admin Rights to Create File */
_file = new File("C:\\Documents and Settings\\All Users\\MyApp\\File.txt");
break;
default:
/* If using a Server OS or other Microsoft Product Default to a User Store */
_file = File.applicationStorageDirectory.resolvePath('File.txt');
break;
break;
case "Adobe Macintosh":
/* Tested on OSX 10.7.5 - Works */
_file = new File("/Applications/MyApp/File.txt");
break;
default:
/* Catch any other Manufacture and default to a User Store*/
break;
/* Return the File */
return _file;}
I made major improvements to the code above
It can be found @ http://code.google.com/p/adobe-air-filex/
Please feel free to check it out, I uploaded a sample air app, complied .swc and the source code
