Show 4 replies
1. Re: Saving a filled-in secure form in Reader?
George_Johnson Oct 10, 2012 10:52 AM (in response to The Real Thorzdad)If it needs to be saved with Reader, the document has to be Reader-enabled. To do this with Acrobat 10, select: File > Save As > Reader Extended PDF > Enable Additional Features
The EchoSign related stuff in Reader should be ignored for a form like this.
Note that Reader 11, which will be released shortly, is able to save a non-enabled form, but not if the form uses digital signatures. If it does, it will need to be Reader-enabled.
2. Re: Saving a filled-in secure form in Reader?
The Real Thorzdad Oct 11, 2012 6:48 AM (in response to George_Johnson)Thanks, George. However, I'm using Acrobat 9 Pro. There isn't a "Reader Extended PDF" option under Save As.
3. Re: Saving a filled-in secure form in Reader?
George_Johnson Oct 11, 2012 7:14 AM (in response to The Real Thorzdad)In Acrobat 9 it's: Advanced > Extend Features in Adobe Reader
4. Re: Saving a filled-in secure form in Reader?
The Real Thorzdad Oct 11, 2012 7:27 AM (in response to George_Johnson)Good grief. I'm embarrassed I never saw that there before.
Many thanks!
