Using Adobe Presenter 7 when published to PDF video files do not just a blank page, any ideas? I am using office 2010 and Adobe Acrobat 9 on my PC any suggestions would be very helpful as the audio and slides work fine though no SWF files work just a blank white screen
What version of Presenter 7? Check at Adobe Presenter > Help > About Presenter
Hi, thanks for the reply, it is version 7.0.7 build 7746
Any advice would be appreciated.
Regards
Nick
The problem seems to be with Acrobat 9. Can you share any such pdf generated from presenter at tcssup@adobe.com.
Alternatively, you can try to download Adobe Reader 10 http://get.adobe.com/reader/?promoid=JZEFU and try to view the published output usingthe same.
Hi, Ok I have just e-mailed you the PDF and also it seems with Adobe 10 and with my Presenter version it does not let me publish to PDF at all, I have attached the image of the error message in the e-mail..something about the PDC converter
Can you uninstall PDC Converter and then try to generate the PDF from Presenter.
