Sorry, it made sense in my little head.
By "everything works" I meant that help does come up to the
proper topic when you press F1 at a from in the application; I just
can't figure out how to specify the target window.
Basically, I have my main help project opening in the
tri-pane window with the browse sequence, table of contents, etc.
When they push F1 to open the context sensitive help from a form in
the application, I want to use a smaller window without all of the
bells and whistles. I have the two windows defined in my project,
but I can’t figure out how to specify the target window in
which the help should open using the Help Provider in Visual
Studio. I was hoping someone here would know where to put the
window call and whether you need to use
Target=”WindowName” or some other syntax.
