I've deployed another ColdFusion 10 RHEL6 server and due to some firewall issues it isn't able to connect to the update center to grab the hotfixes.
So I copied the jar files from another server that I was able to update successfully and ran all the updates manually.
Now when I log into the CF administrator the build/version number has not gone up to what I expect. Does anyone have any ideas?
The installation log had one nonFatalError, but I got the same on the existing server
Installation: Successful with errors.
107 Successes
0 Warnings
1 NonFatalErrors
0 FatalErrors
Existing server with no issues
Server Product | ColdFusion |
Version | ColdFusion 10,282913 |
Update Level | 02 |
Tomcat Version | 7.0.23.0 |
Edition | Enterprise |
Serial Number | |
Operating System | UNIX |
OS Version | 2.6.32-279.2.1.el6.x86_64 |
Update Level | /opt/coldfusion10/cfusion/lib/updates/hf1000-3332326.jar |
Adobe Driver Version | 4.1 (Build 0001) |
New server, updated manually
Version | ColdFusion 10,282462 |
Update Level | |
Serial Number | |
OS Version | 2.6.32-279.9.1.el6.x86_64 |
CF10 mandatory update is the patch that should change the CF version to 10,282913, not updater1 or updater2.
Have you installed CF10 mandatory update JAR?
Note I have not done CF on anything other than Windows for a long time - case R-Linux with CF10 differs to above findings.
HTH, Carl.
Hi Carl,
Sorry I should have been more clear.
On the new server I installed hotfix 1, hotfix 2 and the mandatory update.
So was expecting at the end the version number to be 10,282913
Cheers,
Simon
@raZorTTZ,
The version number issue has been raised with Adobe (most notably by Adam Cameron, see the comments for another post on this forum: http://forums.adobe.com/message/4671031#4671031). He also discusees it at length on this blog entry: http://adamcameroncoldfusion.blogspot.co.uk/2012/09/which-version-of-c oldfusion-am-i.html and this one: http://adamcameroncoldfusion.blogspot.com/2012/09/which-version-of-col dfusion-am-i_5.html.
-Carl V.
It's good to see you be able to recycle that comment! 😉
Adam
@Adam,
Yeah, I think I'm gonna make a 'snippet' out of it!
-Carl V.
Thanks Carl
The version numbering is fixed in today's release.
The current version for fully-patched ColdFusion 10 is 10,0,3,283145.
Cheers for sorting that out, Adobe.
Adam
Woot! No snippet required...
Awesome! Thanks guys and thanks Adobe!
Regarding the nonFatalError, I have had that happen too on RHEL 6. I spoke with adobe engineering about it and they are aware of the issue, it is nothing you need to worry about.
