A different, but no-doubt related, problem to my post How to get 'exit event' script to execute again when form file with saved data is re-opened? of Oct 12, 2012
Setting form properties to ‘automatic’, as suggested by radzmar works fine if data is entered into the form and the file is saved and then re-opened again, but if data is imported into a blank form from an xml file all the ‘hidden’ fields and sub-forms remain hidden regardless of the values now stored for the drop-down lists which should cause various fields and sub-forms to be set to ‘visible’. Any help with this would be very much appreciated.
