1. Re: Why do I lose chapter breaks and TOC when I use the select an existing graphic for cover option? I
Steve Werner Oct 14, 2012 6:53 PM (in response to mckinney3)I'd start with the usual troubleshooting methods: (1) Restore your preferences (2) Export the InDesign file as an IDML file to deal with possible corruption.
That should be happening. Hasn't happened to me in CS5.5 or CS6 when exporting EPUB.
2. Re: Why do I lose chapter breaks and TOC when I use the select an existing graphic for cover option? I
mckinney3 Oct 15, 2012 8:57 AM (in response to Steve Werner)Thank you very much for responding. I tried the techniques you mentioned. (saved as IDML and then opened and tried the export to EPUB from the newly created file.)
Alas I still have the problem. Let me be more precise.
I have a indd file that is very simple and follows an inline structure with all paragraphs being styled, etc.
Page 1 is a placed greyscale jpg file (all one image) that is the size of the document page.
I define TOC and have all my Chapter Headings correctly styled.
I then export as an epub file and first just click on the cover option to be a rastersized first page.
All goes exactly as it should. My Cover is the Title page and the Title Page is intact along with a TOC and page breaks at my chapter headings.
I can substitute a color Title page (the one I really want to be my Book Cover for, say, an iBooks shelf) and all is still OK.
Then I use the grey scale title page.
Export as epub
Then I click on the Cover Page option in the export dialog to use an external file for the cover.
Immediately, the information in the box for Publisher goes away as well as my selections for TOC and Page Breaks.
I refill those boxes and radio buttons and then export.
The exported file has no TOC and all of the page breaks at chapter headings goes away.
All help and suggestions greatly appreciated!
-dan
3. Re: Why do I lose chapter breaks and TOC when I use the select an existing graphic for cover option? I
Steve Werner Oct 15, 2012 12:28 PM (in response to mckinney3)Is it specific to this InDesign file, or can you replicate it with different files? Does it happen if you work from a new user?
4. Re: Why do I lose chapter breaks and TOC when I use the select an existing graphic for cover option? I
mckinney3 Oct 15, 2012 5:34 PM (in response to Steve Werner)I created a brand new document. Brand new paragraph styles. Brand new graphics.
Exact same thing happens.
I created a new user. Logged out and logged back in as new user. Createrd brand new document
Exact thing happens. Trying to use an external file for the cover clobbers the export document as before.
-dan
5. Re: Why do I lose chapter breaks and TOC when I use the select an existing graphic for cover option? I
Steve Werner Oct 15, 2012 6:00 PM (in response to mckinney3)What file format is the grayscale image? What color mode? It may be that InDesign CS5.5 is expecting an RGB JPEG or PNG file.
Try opening the grayscale image in Photoshop and convert to RGB. It will still look grayscale.
6. Re: Why do I lose chapter breaks and TOC when I use the select an existing graphic for cover option? I
mckinney3 Oct 15, 2012 7:13 PM (in response to Steve Werner)The image is already a RGB .jpg image.
-dan
7. Re: Why do I lose chapter breaks and TOC when I use the select an existing graphic for cover option? I
mckinney3 Oct 15, 2012 7:32 PM (in response to Steve Werner)I also reset the Indesign Preferences File.. Same issue.
-dan
8. Re: Why do I lose chapter breaks and TOC when I use the select an existing graphic for cover option? I
mckinney3 Oct 15, 2012 7:53 PM (in response to Steve Werner)I also created a brand new cover image graphic (in case some corruption was present) and selected that image in the export to epub dialog.
Same unexpected result.
-dan
9. Re: Why do I lose chapter breaks and TOC when I use the select an existing graphic for cover option? I
Steve Werner Oct 15, 2012 9:47 PM (in response to mckinney3)I've run through everything I can think of. Is it possible for you to post the file so we could look at it?
10. Re: Why do I lose chapter breaks and TOC when I use the select an existing graphic for cover option? I
mckinney3 Oct 16, 2012 6:46 AM (in response to Steve Werner)Thank you for helping me. VERY much appreciated.
OK, but I do not see how to attach a file on this forum. I can send by email or....
-dan
11. Re: Why do I lose chapter breaks and TOC when I use the select an existing graphic for cover option? I
P Spier Oct 16, 2012 7:25 AM (in response to mckinney3)File attachemnts are disabled. You can use a file transfer service like yousendit.com or DropBox and post a link here (if you want to share withthe world) or put the link in a private message to share with only selected users.
12. Re: Why do I lose chapter breaks and TOC when I use the select an existing graphic for cover option? I
mckinney3 Oct 16, 2012 7:34 AM (in response to mckinney3)OK, it seems that a file cannot be attached directly. But a link can be made to a file in a DROPBOX folder.
An abridged version of the indd file
https://dl.dropbox.com/u/36524202/temporary
An epub document made with the above file by exporting and selecting rasterize first page option for cover
https://dl.dropbox.com/u/36524202/temporary.epub
An epub document made with the.indd file by exporting and selecting external file option for a cover
https://dl.dropbox.com/u/36524202/temporary2.epub
The external graphic that I am trying to use as the cover
https://dl.dropbox.com/u/36524202/red%20background%20cover%20art.jpg
Again, thank you so much for your help!
-dan
13. Re: Why do I lose chapter breaks and TOC when I use the select an existing graphic for cover option? I
Steve Werner Oct 16, 2012 8:16 AM (in response to mckinney3)I could download everything but the InDesign file. It just shows binary garbage. Try Zipping it before you copy it to the Dropbox folder.
14. Re: Why do I lose chapter breaks and TOC when I use the select an existing graphic for cover option? I
mckinney3 Oct 16, 2012 9:37 AM (in response to Steve Werner)Please try this link for the .indd file that was trashed:
https://dl.dropbox.com/u/36524202/temporary.indd
-dan
15. Re: Why do I lose chapter breaks and TOC when I use the select an existing graphic for cover option? I
Steve Werner Oct 16, 2012 2:51 PM (in response to mckinney3)I got the file.
I'm preparing for a class I'm teaching now. I'll try to look at it tonight.
16. Re: Why do I lose chapter breaks and TOC when I use the select an existing graphic for cover option? I
Steve Werner Oct 16, 2012 7:22 PM (in response to Steve Werner)OK, it's definitely not your file or anything you're doing.
It's a limitation in InDesign CS5.5. It's not doing what it's supposed to be doing. It's not really writing the XHTML and the CSS so that your independent cover image can be used.
I was using InDesign CS5.5 when I was learning to create EPUB. I largely used writings by Elizabeth Castro and videos by Anne-Marie Concepcion. In Elizabeth's excellent first EPUB about creating EPUB, she describes how you created a cover (in CS5 days) by creating an XHTML file for the cover, and writing the code (she showed you how), and how you had to make a few changes in the other files I'll describe before.
When I first started creating EPUBs CS5.5 had the Rasterize First Page method. I never tried the independent cover file method. Anne-Marie doesn't even show it in her InDesign CS5.5 to EPUB video.
I was only when I started using CS6, that I tried the independent method and it worked. I never tried it in CS5.5. Not everything is written correctly.
So if you want to continue to use CS5.5, you'll need to create is by modifying code. I'd suggest picking up Elizabeth Castro's EPUB. Here's the link:
Formatting ebooks - EPUB Straight to the Point - Elizabeth Castro
You'll find directions in the Inside an EPUB file > Creating the cover.
To help you, I'm sending you a link to the correctly formed EPUB file created by InDesign CS6:
https://www.dropbox.com/s/bbh9x5liku0kdtg/Edward%20%26%20Amelia%20-%20CS6%20-%20orig.epub
You'll need to use an EPUB editor to add the "CoverImage.xhtml" file to the OEBPS folder.
Then you'll need to add your JPEG file to the "image" folder in the OEBPS (or make an image folder)
Then you'll need to edit three parts of the "content.opf" file: To the metadata, to the manifest, and to the spine.
Or, alternatively, you can upgrade to CS6, which is what I would recommend.
Good luck!
17. Re: Why do I lose chapter breaks and TOC when I use the select an existing graphic for cover option? I
mckinney3 Oct 17, 2012 5:50 PM (in response to Steve Werner)Thank you soooooooo much for trying to help me.
The file you sent that was rendered by CS 6 is still not behaving. The simple title page (grey and white) in the temporary.indd file which is page 1 and what I call the title page is gone. The red external file is now page 1. Rasterizing this title page 1 has always worked properly for producing a cover. The TOC and Page Breaks are OK.
Not sure what you rendered in CS6 but the outcome is still odd.
Page 1 should be the grey and white graphic that is existing page 1 in the file temporary.indd. The exported file should show up with the red external file as the "Bookshelf" cover image. The toc and page beaks should remain intact.
So I am still in a quandry about upgrading to CS6 as this doesn't seem to work either.
What are you seeing on your readers with the file you exported from CS6?
again, I am much appreciative of you helping me. Please hang in here, OK. =)
-dan mckinney
18. Re: Why do I lose chapter breaks and TOC when I use the select an existing graphic for cover option? I
mckinney3 Oct 17, 2012 6:09 PM (in response to mckinney3)When I say not behaving, I am testing on an iPhone, an ipad, Adobe Digital Editions and Calibre.
-dan
19. Re: Why do I lose chapter breaks and TOC when I use the select an existing graphic for cover option? I
mckinney3 Oct 17, 2012 7:58 PM (in response to mckinney3)I tried adding a Cover using the tools in Calibre. as a work around. Calibre locates the external file and adds it to the book as new page 1. The original grey title page is moved to page 2 and so on.
This does create the "good looking" Book cover for bookshelves and retains toc, etc but the same thing can just be done by adding that page in the original indesign document and specifying to rasterize page 1 as the cover in the export dialog.
Can anyone verify that CS6 will retain an original page 1 , keep toc and breaks based on paragrph style AND add a Book cover from an external file as part of the meta data so the graphic shows up on a book shelf but NOT in the book as displayed by a epub reader?
20. Re: Why do I lose chapter breaks and TOC when I use the select an existing graphic for cover option? I
Steve Werner Oct 18, 2012 5:18 AM (in response to mckinney3)I never had any problem retaining paragraph styles and TOC in any of the file you sent me when I tested in ADE.
If you use the external file as I suggested, you do need to delete the extra page which also used when using the rasterize method.
Unfortunately, I'm travelling today and have classes tomorrow so won't be able to do any more testing for a few days.
21. Re: Why do I lose chapter breaks and TOC when I use the select an existing graphic for cover option? I
mckinney3 Oct 18, 2012 7:47 AM (in response to Steve Werner)Thank you for your help! You were very kind to devote so much time to this discussion. =)
I guess we need to close this thread with the conclusion that Indesign CS5.5 has some shortfalls as far as epub exporting. And that CS6 is a step forward.
I find it strange, though that their are many videos and "guru" help blogs that show how to use an external file for a cover in 5.5. I guess they don't really test their work; just want to retread other articles to get words down and attract "ads." =(
dan
