Hi everyone,
is there a way to find out where a certain colour (swatch) is used inside a document, like on what page or something?
Inside a single-page document is not a big deal, in a 200+ paged document it is hell to find out…
I can search for "character colour" and search again for object fill and again for stroke and again and again.
I'm looking for an "easy" way to use.
or maybe there is a script for that?
thanks for helping me out!
following zero budget solutions...
I doubt there's a way to bypass first stage of Steve's method. However, you can avoid entering Separations Preview and manual cycling through hundreds of pages.
Just convert your color to spot, create special Preflight profile and run it:
you'll get the pages where spot colors occur, even more, ID will select it for you when you click on page number in "problem list" in Preflight pallette.
One trick is to temporarily use the Swatches panel to change the color from process to spot. Then choose Window > Output > Separations Preview, and turn on Separations. Turn off the process colors, but turn on the color you're looking for. Page through the document and you can see where it occurs.
Steve,
your solution is an option, though, also time-consuming for large documents.
When using the "Find Font" command in Indesign, and showing "More Info", there you can see on which pages a certain font is used, that is fast and easy.
Hi Winterm,
you made my day!
This is the best-free-fast solution.
I have tried it and it worked real good.
Excellent idea thanks for the info. Will come in very handy
jocstone_me wrote:
Hi everyone,
The commercial Blatner Tools plug-in for InDesign from dtptools.com can find colors and can create a report of all colors or only those used in the current document. There's a 14-day free trial.
I have no connection to the company other than being a satisfied user.
HTH
Peter
_______________________
Peter Gold
KnowHow ProServices
Hi Peter,
thanks for your idea, the plugin is only 99$, so it is to consider …
This video shows you how to use the Find and Replace tool to do this, and it's the best answer, better than replacing with spot colors etc., works for me every time!!!
Latest version (Jan 2021) has Color option in the Find command
