My Adobe Flash Builder 4.5 has stopped working.
I receive the following error when trying to start:
An error has occured. See the log file
C:\ Documents and Settings.......\.metadata.log
I have attached the file.
I have searched the web to try and find a suitable reason/solution but can't seem to find one.
I'm using WIN XP
I had another look on the forums and have managed to cobble together an ini file which launches Eclipse (as the IDE) instead of Flash Builder but it's not ideal although it does seem to work.
It's really very strange.
!ENTRY org.eclipse.osgi 4 0 2012-01-03 07:44:49.085
!MESSAGE Application error
!STACK 1
org.eclipse.swt.SWTError: No more handles
at org.eclipse.swt.SWT.error(SWT.java:4109)
at org.eclipse.swt.SWT.error(SWT.java:3998)
at org.eclipse.swt.SWT.error(SWT.java:3969)
at org.eclipse.swt.widgets.Widget.error(Widget.java:468)
at org.eclipse.swt.widgets.Control.createHandle(Control.java:633)
at org.eclipse.swt.widgets.Composite.createHandle(Composite.java:305)
at org.eclipse.swt.widgets.Control.createWidget(Control.java:649)
at org.eclipse.swt.widgets.Scrollable.createWidget(Scrollable.java:134)
at org.eclipse.swt.widgets.Control.<init>(Control.java:110)
at org.eclipse.swt.widgets.Scrollable.<init>(Scrollable.java:75)
at org.eclipse.swt.widgets.Composite.<init>(Composite.java:95)
at org.eclipse.ui.splash.BasicSplashHandler.getBundleProgressMonitor(BasicSplashHandler.java:159)
at org.eclipse.ui.splash.BasicSplashHandler.getContent(BasicSplashHandler.java:265)
at org.eclipse.ui.internal.splash.EclipseSplashHandler.init(EclipseSplashHandler.java:86)
at org.eclipse.ui.internal.Workbench$8.run(Workbench.java:782)
at org.eclipse.core.runtime.SafeRunner.run(SafeRunner.java:42)
at org.eclipse.ui.internal.Workbench.createSplashWrapper(Workbench.java:798)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2467)
at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:2438)
at org.eclipse.ui.internal.Workbench$7.run(Workbench.java:671)
at org.eclipse.core.databinding.observable.Realm.runWithDefault(Realm.java:332)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:664)
at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.java:149)
at com.adobe.flexbuilder.standalone.FlashBuilderApplication.start(FlashBuilderApplication.java:108)
at org.eclipse.equinox.internal.app.EclipseAppHandle.run(EclipseAppHandle.java:196)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.runApplication(EclipseAppLauncher.java:110)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.start(EclipseAppLauncher.java:79)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:369)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:179)
at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
at sun.reflect.NativeMethodAccessorImpl.invoke(Unknown Source)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(Unknown Source)
at java.lang.reflect.Method.invoke(Unknown Source)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:619)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:574)
at org.eclipse.equinox.launcher.Main.run(Main.java:1407)
!SESSION 2012-01-03 08:05:08.827 -----------------------------------------------
eclipse.buildId=M20100909-0800
java.version=1.6.0_16
java.vendor=Sun Microsystems Inc.
BootLoader constants: OS=win32, ARCH=x86, WS=win32, NL=en_US
Framework arguments: -vm C:\Program Files\Java\jdk1.6.0_24\bin\javaw.exe
Command-line arguments: -os win32 -ws win32 -arch x86 -vm C:\Program Files\Java\jdk1.6.0_24\bin\javaw.exe
!ENTRY org.eclipse.osgi 4 0 2012-01-03 08:05:25.764
!STACK 1
I have the exact issue on 4.6 after updating software...
!SESSION 2012-03-19 06:10:18.084 -----------------------------------------------
eclipse.buildId=M20120208-0800
java.version=1.7.0
java.vendor=Oracle Corporation
!ENTRY org.eclipse.osgi 4 0 2012-03-19 06:10:22.334
!STACK 1
at org.eclipse.swt.SWT.error(SWT.java:4308)
at org.eclipse.swt.SWT.error(SWT.java:4197)
at org.eclipse.swt.SWT.error(SWT.java:4168)
at org.eclipse.swt.widgets.Control.createHandle(Control.java:704)
at org.eclipse.swt.widgets.Control.createWidget(Control.java:744)
at org.eclipse.swt.widgets.Control.<init>(Control.java:112)
at org.eclipse.ui.internal.Workbench$8.run(Workbench.java:790)
at org.eclipse.ui.internal.Workbench.createSplashWrapper(Workbench.java:806)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2528)
at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:2499)
at org.eclipse.ui.internal.Workbench$7.run(Workbench.java:679)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:668)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:344)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:622)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:577)
at org.eclipse.equinox.launcher.Main.run(Main.java:1410)
!SESSION 2012-03-19 06:54:16.071 -----------------------------------------------
java.version=1.7.0
Framework arguments: -showlocation
Command-line arguments: -os win32 -ws win32 -arch x86 -showlocation
!ENTRY org.eclipse.osgi 4 0 2012-03-19 06:55:00.400
!STACK 1
Mee too! What did you do to resolve this?
