How can I can write Arabic in Adobe Illustrator CS ?
I use Adobe® Creative Suite® 6 Design & Web Premi
And I write Arabic in Adobe photshop CS6 but I can't write in Illustrator and indesign
PLZ help me .
You need a font like Geeza Pro loaded, set up your keyboard preference and choose arabic for an input mode. You will want the middle eastern ME version of AI instlaled as typing backwards will not give you accurate results.
Thinks for your help , The link help me to write Arabic in Adobe indesign but in Illustrator I can't
Any way thinkyou .
Write it in ID and paste it into Illustrator that should work although there might be some reflow problems and oncer pasted into Illustrator you might be then able to input the text as you expect.
Thinks , I know that but need to write in Illustrator
In Photoshop, Middle-east/North-african type (MENA) is enabled in all editions. In Illustrator and InDesign, you need the MENA-enabled editions of the software. Please use these links to download the trial and explore Arabic language support in Illustrator:
Cheers,
David
Thinks , but I use Adobe® Creative Suite® 6 Design & Web Premi
Any way thinks .
A solution to enable Arabic in InDesign or in Illustrator is to install ScribeDoor, a plugin from WinSoft Intl: http://store.winsoft-international.com/products/product/winsoft/scribedoor.html
Hope this helps
Pascal
you can get an AI file with arabic formated text already in it, you can then use that existing text and replace it by copying new text into it or typing.
you can also create a paragraph or character style from existing document with arabic in it and apply it to other arabic. you can of course save the character styles into your default document.
you can search for an AI document with different arabic format options and make styles out of those because you won't be able to change type option like Kashidas, arabic or naskh justification
