I have a web app with many states, can I load the app and activate a specific state (not the default) from the url?
Thank you in advanced,
Carlos
Yes, but you need to implement it yourself.
There are two methods.
1. You can set a flashvars parameter in your HTML launch code for Flash. This will be available in the parameters property of your application.
2. You can implement a BrowserManager listener to read the url fragment.
For example, you could do something like this:
[code]
<?xml version="1.0" encoding="utf-8"?>
<s:Application xmlns:fx="http://ns.adobe.com/mxml/2009"
xmlns:s="library://ns.adobe.com/flex/spark"
xmlns:mx="library://ns.adobe.com/flex/mx" minWidth="955" minHeight="600"
creationComplete="application1_creationCompleteHandler(event)">
<fx:Script>
<![CDATA[
import mx.events.BrowserChangeEvent;
import mx.events.FlexEvent;
import mx.managers.BrowserManager;
import mx.managers.IBrowserManager;
// Set a constant for arg name to prevent typos!
public const SELECT_STATE_ARG:String = "selectState";
* Initialise app to use either flashvars parameters or BrowserManager to set state.
* Will respond to selectState value in either fragment or flashvars.
protected function application1_creationCompleteHandler(event:FlexEvent):void
// Method 1: This tries to load based on value of selectState in flashvars in your launch code.
if(parameters && parameters[SELECT_STATE_ARG]) {
tryState(parameters[SELECT_STATE_ARG].toString());
// Method 2: Set up browser manager to listen.
// 1. Get instance
var bm:IBrowserManager = BrowserManager.getInstance();
// 2. Init to get current url
bm.init();
// 3. Add event listener for hash tag changes
bm.addEventListener(BrowserChangeEvent.URL_CHANGE,processBrowserChange);
// 4. Call listener once to set initial state.
processBrowserChange(null);
* Try going to the specified state or go to errored state with details if it fails.
protected function tryState(tryLoadState:String):void {
try {
currentState = tryLoadState;
} catch(e:Error) {
errorDetails = "State not found: "+tryLoadState+"\n"+e.toString();
currentState = "errored";
[Bindable] protected var errorDetails:String;
* Look for a fragment and search for selectState - try loading that state if found.
protected function processBrowserChange(event:BrowserChangeEvent):void {
var tryLoadState:String;
var fragment:String = bm.fragment;
if(fragment) {
try {
var uv:URLVariables = new URLVariables(fragment);
tryLoadState = uv[SELECT_STATE_ARG];
} catch(e:Error) {
errorDetails = "Could not parse: "+fragment+" as URLVariables\n"+e.toString();
return;
if(tryLoadState) tryState(tryLoadState);
</fx:Script>
<fx:Declarations>
<!-- Place non-visual elements (e.g., services, value objects) here -->
</fx:Declarations>
<s:states>
<s:State name="aState" />
<s:State name="aNotherState" />
<s:State name="yetANotherState" />
<s:State name="errored" />
</s:states>
<s:VGroup horizontalCenter="0" verticalCenter="0">
<s:Label text="currentState is {currentState}" />
<s:Label text="{errorDetails}" color="#ff0000" includeIn="errored" />
</s:VGroup>
</s:Application>
[/code]
That will allow you to change the state of your app on demand by linking to, for example:
http://<myUrl>/myapp.html#selectState=aNotherState
Cheers,
G
