A web browser's Print command provides unpredicatable results
for users for Robohelp documentation.
1) You can add a print command to any frame by inserting the
following javascript command in the hyperlink "Link to:" field for
the print graphic or text command that you insert :
javascript: window.print()
However, for consistency in your documentation, this needs to
be inserted on every page, or in the header or footer used on every
page in your manual.
2) A better solution would be to add a print icon and label
to the toolbar. (The javacript above enables you to print the
content of the frame in which it is located - the toolbar; this is
not useful.) You need to use your skin editor to add a custom item
to the main toobar. In the Action window, select Javascript, and
OnClick. Then insert the following javascript command:
javascript:framePrint('FRAMENAME')
All you (and I, unfortunately) need to know is the name of
Robohelp's content frame to make this work. Does anyone know the
name of the content frame in Robhelp's standard three window frame
set?
