Show 2 replies
1. Re: Exporting Image from Acrobat
Dave Merchant Oct 25, 2012 10:18 AM (in response to ZenDao)Acrobat is simply exporting the embedded version of the graphic from within the PDF file. InDesign embedded it according to the settings you used on the document at the time, so it won't usually be the same as the original image file InDesign was linking to.
2. Re: Exporting Image from Acrobat
George_Johnson Oct 25, 2012 10:22 AM (in response to ZenDao)When you generate the PDF, all of the image data is stored in the PDF and in no way relies on an external file. When you export an image from the PDF, it takes the image data and generates a new file that will necessarily be different than the original source file, for a number of possible reasons (different physical size [as in your case], different compression method, downsampling, etc.)
