I am really struggling to open a particular .prproj source file with a file size of 2.2GB. While the smaller files are opening and editing flawlessly. I am wondering why a file could be so large given that the smaller files are duplicates (161mb) and contain almost all the same information. The only thing I can imagine is that I know that file has been rendered A LOT, so that has increased its size expodentially.
I switched recently to Premiere from FCP so a bit at a loss. If I delete the render files and restart will that reduce the project file size? If so, were are the render files? Under preferences there is a media cache file in /application support totalling 8.5GB. Any idea if that is it?
Warp Stabilizer is notorious for making project files huge. Did you stabilize any of your clips?
Thanks Steven, no, I have not used the stabilizer but have used several filters such as color corrector etc. I cannot even open the file at the moment though some earlier versions are opening and editing nicely. Do you know were the render files are ordinarily kept (or how I can find them) so I can delete them and hopefully decrease the file size?
I am editing on a macbook pro 2.66 GHZ w/ 8GB of RAM. Not sure how I can keep this info my profile to avoid retyping it every post...though I did search around..
Just look in the Sequence menu for "Delete Render Files".
I don't know for sure, but I think it is more likely that will reduce your file size than looking for the files and deleting them yourself.
I do that every so often for big projects to keep the disk usage down. I just rerender when I am about to go to dinner or watch a little TV.
To be honest I have never paid much attention to the size of the project file.
Problem is that I can't open the file Steven. If I can delete the actual render files first, maybe I can open the file/ sequence menu and do as you suggest..problem is, I am not sure were they are.
Search your hard drive for "Adobe Premiere Pro Preview Files".
I don't know if the directory is named the same on a Mac, but it is worth a try.
Otherwise, since on a PC the files end in .avi I would guess that yours end in .mov - and maybe they begin with the word Rendered like mine do? Search on "Rendered" and see if you can find them.
Hi Steven, I know where all my rendered files are being kept but if I delete rendered files that I am currently editing on premiere pro, will it 'un-render' the files or potentially delete the files on the opened sequence? I also want to ask that if I delete my rendered files from a previous project but is still in premiere pro file format, and when I open the project again, will the file's be unrendered?
Render files and preview are not original media. Render files and previews are used for playback and both can be recreated at need.
Neil
You can delete the cache file you have in premiere pro preferences. Heres a link Clean those Adobe Media Cache Files by Scott Simmons
The render files are also in the preview/render files that you can delete in the "Premiere Pro Preview Files" folder, these usually aren't large files so I'd go for deleting the cache files.
You can try to import the same project in a new one and check the size of the project.
Thank You
Arjun
