Hi
I need to place a download button graphic that has a link to a bio in the PDF format, which is different for each web app item. I know how to use the Item Description and place code there, but would rather have a field using a field. The button graphic is the same for all, just there is a different link for each.
Anythoughts?
Thanks, in advance!
_value here Joel.
<a href="{tag_pdf_value}><img src="{tag_image_value}"/></a>
Use the custom image field. You can browse more then images with it such as a pdf.
Okay, great I will try that.
That works well as it lists the file name, but any suggestions to having that link applied to a typical image placed in the app detail layout.
I tried inserting the tag_ into the <a href="{tag_}"><image></a> but that didn't work.
Any alternatives?
Thanks so much in advance.
_value here Joel.
I will try that as well, as that seems like more a direct approach, rather than my round-about.
Thanks, Teejay
Excellent solution. Thanks Liam.
No Problem
SOLVED! I used a Multiline Text field was able to place HTML code inside of it. I wasn't sure at first because it wasn't like the content editor. Sweet.
