Hello, I hope someone can help with the installation of standalone flash.
My system is Vista 32bit, with Chrome (latest update), and due to problems with CPU at 100% causing game lag and freezing, I decided to try the standalone version.
However, when I paste an address into the standalone, it does not connect - it does nothing at all. I tried disabling the flash in Chrome but this did nothing. I can resize the standalone window and change the quality setting, but nothing else.
I deleted the standalone, then downloaded a fresh one but this is exactly the same. Is it possible that it needs Java to run ? I do not have Java on this computer.
I would be grateful for any suggestions,
Thanks.
Unfortunately you're not going to be able to use the standalone/projector file like that. It's meant to load a swf file, not a webpage.
Have you tried using a different browser or changing Chrome to use the system copy of Flash Player instead of it's built in version?
http://helpx.adobe.com/flash-player/kb/enable-system-flash-player-google-chrome.html
Thanks for the reply and the helpful link. The previous version of Chrome that was installed had the two flash versions - and it helped when I disabled the pepper version. However, I seemed to gradually get more lag and freezing / crashing etc, so I did a full system re-install.
I then downloaded the latest Chrome (a few days ago), and this has :
Flash - Version: 11.4.31.110
Shockwave Flash 11.4 r31
Do you think it best to download a separate flash and then disable the one built into Chrome ?
The strange thing about the standalone flash is that I've actually used it before to play the browser game (this was around 6 months ago) !
I have previously used Maxthon browser which has flash built-in, so I might give this another try.
Thanks.
If you have a link to the game's swf, you might still be able to play it with the stand alone/projector version of Flash Player.
As for installing the plugin version (and disabling Chrome's version), I'd say give it a try. You might want to use our 11.5 beta version to see if that helps.
Thanks again. Here is the link to the game :
I just added the address to standalone flash but still no joy I'm afraid.
I will try the beta version,
Thanks very much.
Update - I installed the beta flash and disabled the one built-in to Chrome. The game is more responsive with just occasional lag. The CPU has dropped from 100% continuous down to between 92 - 95%.
For some reason, the beta standalone will not open the flash game. It behaves the same as the stable version.
