i have a loop setup on an insert that was running fine on cf9, but on cf10 it is erroring with an "expressions error"
code is:
<cfloop index="x" from="1" to="#cc#" step="1">
<cfif IsDefined("FORM.["Interest" & #x#]") AND FORM.["Interest" & #x#] is 1>
1
<cfelse>
</cfif>
</cfloop>
it is looping through a form field "Interest1, Interest2, Interest3", etc
cc is the number of form fields
any suggestions appreciated.
thanks.
code is:
Sorry, but that code you specify there will not run on any version of ColdFusion.
Firstly you have a syntax error in your variable referencing as others have pointed out. This is invalid:
It needs to be this:
FORM["Interest" & #x
...Copy link to clipboard
When I use array notation, I don't have a period between the structure and the opening square bracket. Given that CF tends to be less forgiving of those sorts of imperfections as the versions get higher, that might be the problem.
thanks, but isn't the period necessary to separate the input type from the name of the form, e.g. FORM.Interest1 vs FORMInterest1
If written without the loop, it would be:
<cfif IsDefined("FORM.Interest1") AND FORM.Interest1 is 1>
1
<cfelse>
</cfif>
<cfif IsDefined("FORM.Interest2") AND FORM.Interest2 is 1>
1
<cfelse>
</cfif>
<cfif IsDefined("FORM.Interest3") AND FORM.Interest3 is 1>
1
<cfelse>
</cfif>
form["interest"&x] is, I believe, the proper notation.
^_^
Regarding, "thanks, but isn't the period necessary to separate the input type from the name of the form, e.g. FORM.Interest1 vs FORMInterest1'
Not when I do it.
Not when I do it.
Nor when anyone else does it in the context the OP is using it.
As you know, Dan: it's necessary when using dot notation (hence... err... the name "DOT notation"), but it's invalid when using associative array notation as we have here. It's not "less than ideal" or "not the way I prefer doing it", it simply doesn't compile.
Adam
OFF TOPIC
Hey Dan, whilst you're lurking... did you get my direct message the other week (last week?)?
Adam
I got an private message? Hey Adam, did you get the reply I sent a couple of seconds ago?
code is:
FORM["Interest" & #x#]
(ie: without the dot).
Secondly, isDefined() only works with dot-notation variable names, eg: form.interest1 etc. It cannot be used with associative array syntax or any other sort of notation. so - syntax errors aside - this will not work:
(oh... a third error... if you're using double quotes as the string delimiter, and have embedded double quotes in the string, you need to escape them, eg "". However that is neither here nor there in this situation, as the code is broken in two other ways anyhow.
So you're giving us misleading information there.
What you want to be using is this:
structKeyExists(form, "Interest#x#") and form["Interest#x#"]
Although using the & operator will work fine there too, instead of the inline variable resolution.
Avoid isDefined() altogether if poss, as it's a bit old and creaky and gives false positives compared to using structKeyExists(), which just works.
Adam
Thanks for the help. Got it working now.
